Results 1 to 18 of 18
Thread: Valve Cover gasket for '86 VF500F
    Member droopydawg's Avatar
    Dec 2007
    Decatur, Ga
    '86 (Honda) VF500, '86 (Yamaha) SRX600, '87 (Yamaha) SRX250, '07 (Triumph) Tiger 1050, '66 (Sears) Sabre 50, '66 (Ducati) Monza 250, '64 (Benelli) Cobra 125, '67 (BSA) Thunderbolt 650.
    42
    So apparently, BikeBandit feels that the valve cover gasket for a VF500C (magna) will work just fine for a VF500F (interceptor). They are saying some crap that the OE part has been disconntinued by Honda, and some modification to the Magna gasket may be required to work on the VF500F. Sure. Like to see someone fabricate just the right rubber compound and adhere it to the Magna gasket to cover those exposed cam shaft ends.
    So. Anyone here have a solution? I can always just run it as a total loss lubrication system....like the good old days. That ought to be fun. The cagers and environmentalists would love that.
    Thanks.
    Senior Member Longerfellow's Avatar
    Aug 2007
    Pollock Pines, CA
    1997 Honda VFR750F & lots of little Honda stuff
    397
    Have you tried this site?
    http://www.ronnies.com/micro.htm
    I just looked there and they seem to have them.
    Dec 2007
    Decatur, Ga
    42
    Quote Originally Posted by Longerfellow View Post
    Thanks. I'll check them out.
    Dec 2007
    Decatur, Ga
    42
    Ronnie's claims that this valve cover gasket is discontinued too.
    Surely, people have to still replace that gasket everyonce in a while. I know it is not necessary every time you adjust the valves, but someone has to have a replacement. Even non stock.
    Anyone have ideas? Too much to use liquid gasket, I would think.
    Aug 2007
    Pollock Pines, CA
    397
    Quote Originally Posted by droopydawg View Post
    Anyone have ideas? Too much to use liquid gasket, I would think. think a valve cover for a VF700F would work?
    Well, how 'bout that! Do you know what modification was required for the magna gasket? Maybe it's just trimming off a tab or something similar. I know that dealers are a bad word to some, but have you asked a dealer in your area what their opinion might be?
    Dec 2007
    Decatur, Ga
    42
    Actually just the opposite. I need a tab, 8 to be exact. They cover the cam shaft ends. The area to cover, i think, is to large to incorporate liquid gasket with the magna gasket. about the size of a nickel.
    Aug 2007
    Pollock Pines, CA
    397
    On the old nighthawks they had the "half moons" you're looking for. See the picture. You'd have to check the size of course, but it's an option. I believe in the picture they're labeled #10.
    Aug 2007
    Pollock Pines, CA
    397
    Here's the part #. it's a start CAP, CYL HD SIDE
    12331-ME5-010 (replaces 12331-ME5-000)
  9. #9
    Dec 2007
    Decatur, Ga
    42
    Yea, sort of. My half moons are part of the actual gasket material, and not an insert. See BikeBandit schematic for '85 VF500F. They dont even list '86. thanks for going to the trouble though.
  10. #10
    Aug 2007
    Pollock Pines, CA
    397
    I misunderstood. I thought you had access to gaskets without tabs and were looking for tabs. Good luck in your searching.
  11. #11
    Dec 2007
    Decatur, Ga
    42
    no no no. i guess i am miscommuniciating. i need gaskets with the half moons as part of the gasket material. all that i can find is Magna type gaskets or VF700 type gaskets. Basically, I need the OE gasket for '84 - '86 VF500F. thanks. a bit frustrating to try to figure out why Honda would discontinue a part for a vehicle that is only 22 yr old.
  12. #12
    Uber Guru JamieDaugherty's Avatar
    Aug 2006
    Fort Wayne, IN
    2008 Ducati 1098 - 1998 VTR1000F - 3x 1984 VF500F - 1984 VF1000F - 1985 VF1000R - 1984 VF700F
    1,420
    Blog Entries
    The Magna parts should be exactly the same. Have you tried Cometic or Parts Unlimited?
    To answer one of your other questions: no, these aren't replaced unless they get damaged. I've reused them multiple times on engines without any problems.
  13. #13
    Senior Member masonv45's Avatar
    Apr 2007
    1985 VF700F
    790
    Why do you think the gaskets need to be changed?
    1985 VF700F (Parting)
    Memphis, TN
    SabMag FAQ: http://wiki.sabmagfaq.org/
  14. #14
    Dec 2007
    Decatur, Ga
    42
    Yes, they need to be replaced. they are shredded. The PO damaged them and tried to repair with liquid gasket. I stress tried. Yes, they should last a long long time, between valve adjustments. I already ordered the gaskets. When they showed up, they did not look like the ones I took off. Both BikeBandit and local honda dealer say they are the same.
    They dont look like it to me. Am i losing my mind? Now, my bike is a '86, but would use the same gasket as a '85.
    '85 VF500F Interceptor*** http://www.bikebandit.com/houseofmot...m9686sch408132
    '85 VF500C Magna***
    http://www.bikebandit.com/houseofmot.../m2750sch93994
  15. #15
    Senior Member Chris71Mach1's Avatar
    Dec 2007
    Arlington, TX
    1987 VFR700F2; 1998 Yamaha YZF600R
    173
    www.ronayers.com
    www.powersportspro.com
    one of these 2 websites has GOT to have the gasket ya need, dude.
    Ride like it's your last day on earth!
  16. #16
    Dec 2007
    Decatur, Ga
    42
    Quote Originally Posted by Chris71Mach1 View Post
    www.ronayers.com
    Thanks. I will try RonAyers. Already tried PSP.
  17. #17
    Mar 2008
    Here you go. I can't say the the 84, 85 gaskets will work on the 86 though. Maybe someone here knows.
    http://cgi.ebay.com/ebaymotors/NOS-C...spagenameZWD1V
    If the link doesn't work search Ebay for VF 500 gasket.
    Chris
  18. #18
    Dec 2007
    Decatur, Ga
    42
    Quote Originally Posted by cromanyak View Post
    Chris
    DUUUUUUDE! Thanks a bunch! Yes, they will work. I bought two of them. I looked in ebay a lot, but did not think of looking with a space between vf & 500.
    Ok. Ok. I will stop whining now.
  1. VF500F Gasket Sources
    By invisible cities in forum 1st & 2nd Generation 1983-1989
    Last Post: 11-28-2009, 09:58 AM
  2. VF500F Gasket Kit Reference
    Last Post: 11-24-2009, 04:01 AM
  3. front sprocket cover gasket?
    By jay956 in forum 3rd & 4th Generation 1990-1997
    Last Post: 04-06-2009, 04:09 PM
  4. Valve Gasket & Carb Questions
    By BohemianVF in forum 1st & 2nd Generation 1983-1989
    Last Post: 09-09-2008, 02:38 PM
  5. sealant on clutch cover gasket??
    By love4vfr in forum 3rd & 4th Generation 1990-1997
    Last Post: 02-23-2008, 04:14 PM
