Results 1 to 18 of 18
Thread: Help re-installing Petcock
    Senior Member slowbird's Avatar
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    Okay...so with the aid of the attached pictures someone can please help me re-install everything and attach the lines properly.
    I've labeled the hoses that are attached to the bike (located under the tank) as A & B
    Another pic shows where Line A goes.
    The last Pic is of the Petcock and all the assorted Nipples and such.
    I'm gonna venture a wild guess and say Hose #3 on the Petcock goes to Hose B on the bike.
    What about everything else?
    1986 Honda VF500 Interceptor
    Pretty fart smeller....
    derstuka's Avatar
    Jan 2007
    San Diego, CA
    1998 Honda VFR800FI
    4,275
    Contact Jamiedaughtery (sp?) on this forum. He is an expert on those bikes.
    ~Jason
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    I'm hoping he or anyone else that knows what do do just see this and gives me an answer.
    I have a few days until my Tank is done anyways.
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    Bump.....anyone know?
    derstuka's Avatar
    Jan 2007
    San Diego, CA
    1998 Honda VFR800FI
    4,275
    Again sir....contact member Jamiedaugherty (send him a PM, private message that is). Threads get buried sometimes before the right people with the right answers see them.
    ~Jason
    Member pjrocco's Avatar
    Apr 2008
    Aurora, IL
    84' Honda VF500F & 05' Honda CBR600F4i & 78' Honda CB750 & 03' Honda XR50
    89
    #3 is your main gas line, #2 stays open and #1 is for the vacuum line.
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    Great! Thanks!
    Question #2:
    When I tun the Fuel Selector Knob from On to Off and to RES...I can't see anything moving. Even when I look into the little copper tube. Is this normal?
    Is there not something that moves up and down to select a different fuel level in the tank?
    Apr 2008
    Aurora, IL
    89
    Quote Originally Posted by slowbird View Post
    Great! Thanks!
    Question #2:
    No, there is nothing you can see moving in the petcock, it is all managed within the assembly.
  9. The Following User Says Thank You to pjrocco For This Useful Post:
    slowbird (07-14-2008)
  10. #9
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    GREAT!
    Thanks.
  11. #10
    Uber Guru JamieDaugherty's Avatar
    Aug 2006
    Fort Wayne, IN
    2008 Ducati 1098 - 1998 VTR1000F - 3x 1984 VF500F - 1984 VF1000F - 1985 VF1000R - 1984 VF700F
    1,420
    Blog Entries
    I think you've got it all squared away!
  12. #11
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    Quote Originally Posted by JamieDaugherty View Post
    There was a while there when I was answer-less. But I'm okay now.
    Thanks Jamie!
  13. #12
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    New question....how does the Petcock seal itself to the tank? With the little O-Ring there?
    I re-installed everything and it was seeping gasoline. The O-Ring seemed fine.
    I used some Gasoline Resistant sealant to attach the Petcock to the tank and it didn't leak...but now everytime I start the bike it pours gasoline fron somewhere under the tank. I'm unsure where cause I can't start the Bike and run it AND look under the tank for where it's leaking from.
    I'm assuming that since it only leaks when it's running that it must be from the hose that goes from the Petcock to the Carb Line.
  14. #13
    Apr 2008
    Aurora, IL
    89
    Yep, the little o-ring that goes between the tank and the main inlet is what seals the tank to the petcock. I am guessing it is not the tank that is leaking and it is the petcock its. Below it a post I made to help another user with your same problem.
    Quote Originally Posted by pjrocco View Post
    If you look at "12" in the photo from left to right you should have; first metal valve, then nipple/metal cylinder(bridge)/diaphragm, plastic chip to hold spring, metal cap (vacuum).
    The first metal piece should go between the nipple and diaphragm equal to the metal cylinder(bridge). If the nipple is not through the first metal value then there is no gasket and the gas will leak out.
    Hopefully this makes sense... I'm horrible and typing what I'm trying to say.
  15. #14
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    But would it make sense that the Seal between the Tank and the Petcock will only leak when the engine is running?
    before it was leaking even before i started the engine and it was from the o-ring between the Petcock and the Tank but after I sealed that up and it wasn't leaking anymore I installed everything and it leaks now only when the bike is running.
    ...and it doesn't leak...it GUSHES! But only when the Bike runs.
  16. #15
    Senior Member Longerfellow's Avatar
    Aug 2007
    Pollock Pines, CA
    1997 Honda VFR750F & lots of little Honda stuff
    397
    Hello,
    Two things come to mind. When your engine is running, vaccum is applied at the petcock opening the valve in the petcock. Can you get a mirror in there to see?
    Now my far fetched theory: Was your bike sitting. Is there a chance that some of your your fuel has leaked to your crankcase (a fairly common occurance when sitting) thus over filling it? When this happens the fuel oil mix can be pumped to your airbox via breather hoses and leak all over everywhere. Either theory should be easy to dismiss or substantiate. Good luck.
  17. #16
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    My bike sat for almost 2 weeks. It had the Tank removed the whole time so the only gas left would have been in the lines of in the carbs.
    I covered and plugged up everything while the tank was off.
  18. #17
    Apr 2008
    Aurora, IL
    89
    I'm pretty positive that it is not the seal from the tank to the petcock and it is actually the petcock itself. I had this same problem and I had to rebuild the petcock and make sure the nipple and diaphragm were in correctly.
    It is leaking because once vacuum is applies it is opening up the diaphragm/nipple and since it is not seated correctly the gas is leaking out of the seams. I would suggest getting a small mirror and actually pin pointing the leak. It is hard to tell where it is leaking from when you can't really see it up close.
  19. #18
    Apr 2008
    Brampton, Ontario.
    1986 VF500F
    671
    I re-installed everything on Thursday. I got the little wire/spring clamps for the Fuel hose on the Petcock and streatched them so they'd be tighter on the hoses. I re-installed all the lines and It didn't leak.
  1. Not installing new fuse box
    By RedMenace in forum Mechanics Garage
    Last Post: 04-20-2009, 05:42 PM
  2. Installing a PCIII on an 05
    By koggs in forum 6th Generation 2002-2009
    Last Post: 05-05-2008, 12:15 AM
  3. Installing FSD Led undertail on an 06
    By canib in forum Mechanics Garage
    Last Post: 09-01-2006, 05:14 PM
  4. Installing SportVue MC2
    By texvfr800 in forum Mechanics Garage
    Last Post: 04-22-2006, 08:55 AM
  5. Problem after installing K&N Filter??
    By woodcycl in forum Mechanics Garage
    Last Post: 06-20-2003, 04:06 PM
