Results 1 to 21 of 21
Thread: Fuel Tank and Carb Questions
    Apr 2009
    Rockford, IL
    86 VFR700
    9
    This is my first post here as I have just bought a 86 VFR700 and have a few questions. The carb and tank were both off when i got it and am confused on a few things.
    1. There are two spouts on the bottom of the tank one to the fuel pump then the carb, but im not sure where the other spout goes to.
    2. On the carb there is a short "fuel line" that comes out of the carb near the gas line in from the fuel pump that is only like 6 or 7 inches long and is open hanging there. Im not sure if its just cut and suppose to go all the way to the other tank spout or its just a air vent.
    3. on the oil cooler there are on both sides, below the actual oil lines, a short rubber tube thats only 4 or 5 inches long hanging there. Are they just vents?
    Sorry if the descriptions are vague Im new to the vfr's, my newest bike I own is a 75 Honda CB200T.
    Thanks for any help you can throw my way.
    Senior Member volks6000's Avatar
    Nov 2008
    North Florida
    84 VF500F
    370
    just sit back someone with a 700 or 750 will be along to help you out.
    Senior Member Ghost's Avatar
    Jul 2005
    Kernersville, NC
    1987 VFR Interceptor 700F2
    329
    Grelcome!
    (Grats and Welcome)
    Quote Originally Posted by Weseal View Post
    1. one size is about 7/8 O/D with a 3/8 ID, black. This is your fuel. The other is a polytube. Approx. ¼ OD and 1/8 ID. This is a vent, route it along the RIGHT side of the bike, through the frame, there is a small “double back” clip to set this hose in.
    2. it was cut, please get another one. This also is a vent, route it through the frame, to the same location as the Gas tank polytube.
    3. This is an oil/pressure over-flow tube. If your oil temp and pressure rise too high, much like a water thermostat valve, this will open up, and spew hot as fuck oil wherever the tube is. Ensure the tube doesn’t point near where one of your legs will be.
    I have an 87 VFR Interceptor 700F2. Our bike makes are extremely close. I have 100% disassembled this bike, and know its workings fairly well. I’m sure you will enjoy this bike, I have. Perhaps you can help settle a bet… is the bike in “TOP GUN” that Tom Cruise rides while “chasing” an airplane, an 86 or 87?
    Uber Guru squirrelman's Avatar
    Jul 2006
    Barf-a-load, ny
    '86 VFR 700Fs (3)/ '97 VFR 750F/ '88 NT 650 HAWK (3)/ '86 Yamaha Radian/ '66 Yamaha YL-1/ '88 VTR 250 / '73 CB 125
    2,284
    Count yourself a VFR expert if you can git dem carbs back on without lots and lots of cussin'
    Apr 2009
    Rockford, IL
    86 VFR700
    9
    Yeah well i got them on with a lot of blood and sweat. Problem was when i got them on i noticed one of the vent lines was cracked and had to take the carbs back off! So I ended up ordering new rubbers so that it hopefully wont be so difficult next time.
    Anyone have any suggestions of a good place to find parts for my bike other than ebay and the local "expensive" honda dealer?
    Jul 2005
    Kernersville, NC
    329
    check here for a quick ref guide
    http://vfrworld.com/forums/first-sec...s-sources.html
    For this year bike, I would check ebay a lot, local bike scrap yards, bikebandit.com for some parts, and keep a posting in the classified's here on this website...Honda dealer only if you are impatient, or have money to burn.
    Apr 2009
    Rockford, IL
    86 VFR700
    9
    Well after taking the carbs on and off about 7 times total, the bike idles with no choke. Its still has a little hesitation but its getting better. I still think its not firing on one cyclinder. I got two of the slow speed jets out and two I can that are stuck in the carbs. I broke the slot head off of them trying to remove them. I tried a little heat to see if i could break them loose but they are in there. Anyone have any suggestions on how to get them out?
    Also do you recommend the jet kits they sell on ebay?
    Senior Member woody77's Avatar
    Dec 2006
    Santa Cruz Mtns, CA
    1986 Honda VFR700F
    362
    If they're that stuck in place, I'd soak it in solvent (pull all the plastic/rubber bits off), and see if that helps.
    For jet kits, my experiences recently with my wife's hawk have made me big fans of Factory Pro's kits and expertise. Definitely better than Dynojet.
  9. #9
    pokerplayer6989's Avatar
    Mar 2009
    missouri
    86 honda interceptor vfr 700f (died) 88 cbr 600 hurricane
    116
    just posting im in the middl eof a vfr 700 rebuild but im having a hell of a time there is a guy on here who has helped me alot. get ahold of toxic shock i thing he can set you right
  10. #10
    May 2008
    86 700 vfr carb jet question
    sorry hit the wrong reply button
  11. #11
    Apr 2009
    Rockford, IL
    86 VFR700
    9
    I forgot to mention that the bike has a yoshi exhaust, k&n airfilter, and drilled airbox.....would that make a difference?
  12. #12
    Senior Member fatso1277's Avatar
    Mar 2007
    South Suburb IL.
    1987 Honda VFR700F2
    256
    welcome to board, sorry can't answer to many of your questions, but we are in the same state maybe we can ride together as soon as i put this damn bike back together, so many projects, so little time....enjoy the bike.
    Oh checked out your powdercoating page...nice work. might have to send some business out your way..
  13. #13
    Apr 2009
    Rockford, IL
    86 VFR700
    9
    Sounds Good...
    Good news i got the bike running great and had my first ride on a VFR today! I think the majority of my problem was that the owner before me drilled out the air box, installed a yoshi pipe and k&n airfilter which caused a lean fuel problem. So i bought a non drilled airbox top installed and it runs like a raped ape now. I love this bike. Now all i need to do for this season is work on some of the fairings which are in rough shape and im set.
    This next winter i will tear the bike completely apart and powder coat, paint, and rebuild everything possible. But for now lets ride!
  14. #14
    short fused
    crustyrider's Avatar
    Jul 2008
    Santa Barbara CA
    1986 Honda Interceptor VFR700F2
    2,173
    Sounds Good...
    nicely done....the fairings are gonna be a hard one to find..if your good with fiberglass you can fix them( I did and the look alright, but I suck doing body work)
    congrats again
    CR
  15. #15
    Mullet Aficionado
    TOE CUTTER's Avatar
    Nov 2008
    Sacramento
    2007 RWB 1990 RED 1986 750 DRZ 400
    1,781
    86 750
    Pulling a 750 apart tonight that has sat since 03 . I will post pics.
  16. #16
    Apr 2009
    Rockford, IL
    86 VFR700
    9
    Ive got a good body guy in house who said that he could get them looking good as new. I just need to find some inner fairings that fit up front between the frame and front fairings.
  17. #17
    short fused
    Jul 2008
    Santa Barbara CA
    2,173
    Quote Originally Posted by TOE CUTTER View Post
    wow be sure to say a word or two about the sacrifice you are about to make.....
  18. #18
    Mullet Aficionado
    TOE CUTTER's Avatar
    Nov 2008
    Sacramento
    1,781
    Not This One
    Sorry Crusty this one belongs to a friend of mine that got hurt and is getting ready to ride again and I am just getting it running and road worthy again, but our parts bike will turn up eventually
  19. #19
    Mullet Aficionado
    TOE CUTTER's Avatar
    Nov 2008
    Sacramento
    1,781
    Gen 2
    Tube under the tank just in front of the fuel line is the over fill under ther fuel cap and dumps to the ground. The tubes on the cooler are to catch and dump leakage from conectors away from front tire. Heres a picture , is the line you described in this picture?
  20. #20
    Mullet Aficionado
    TOE CUTTER's Avatar
    Nov 2008
    Sacramento
    1,781
    new thread i
    I will start a new thread for carb cleaning
  21. #21
    Junior Member agfirecat's Avatar
    Mar 2009
    16
    thanks for that picture toecutter now i realized on my 2nd gen that somebody installed the valve cover with the vent on it on the front half of the motor.I was wondering where the hose on the air box was supposed to go. my carbs were off when i got mine and i had to seperate the front and back to get them back on what a pita that was wound up cracking one of the rubber manifolds and the plastic fuel line snapped. im new to the site and im geting alot of usefull info to get my f2 back together
  1. More Carb Questions...
    By Unzie57 in forum Mechanics Garage
    Last Post: 06-05-2009, 03:30 PM
  2. Valve Gasket & Carb Questions
    By BohemianVF in forum 1st & 2nd Generation 1983-1989
    Last Post: 09-09-2008, 02:38 PM
  3. Magnetic Tank Bag questions?????
    By Galo in forum Gear & Accessories
    Last Post: 07-29-2008, 07:21 PM
  4. Fuel delivery?? Pump or Carb??
    By loopsandlogic in forum 1st & 2nd Generation 1983-1989
    Last Post: 05-25-2008, 09:46 AM
  5. Carb fuel line routing question...
    By dlman in forum 1st & 2nd Generation 1983-1989
    Last Post: 03-05-2007, 06:40 PM
