duffman723 (06-18-2009)
Ive looked on ebay and checked a few salvage yards but have come up with nothing.
If any one has one for sale or has a line on one, please let me know.
Thanx for any help.
When i rebuilt part of my Petcock the guy at Honda parts said you could order a complete Petcock Assembly.
1986 Honda VF500 Interceptor
I think I may have one laying around from the old 86'... Drop me a PM and I'll look tonight when I get home.
Thanks for the advice but I tried that in my area(mn) and was told by 3 different shops that the assembly is discontinued for the 1986 model.
If you can find a new one, please point me in that direction.
Used in good condition would be fine too.
This was a reply to slowbirds post.
I bought the complete assembly for my 500 about 6 years ago. I was told back then that Honda only had 3 left in stock before they were gone. I also bought a brand new gas tank that I still have in the box in which they said was the last one in American Honda inventory. With that said, you will probably have to go used. eBay does have quite a few parts for the 500. Also, have you checked any local bike shops to see if they have parts bikes? It might be worth a call.
Proud Owner - 1st Gen Interceptor (1986 VF500F)
Proud Owner - 2nd Gen Interceptor (1986 VFR750F & 1986 VF1000R)
Proud Owner - 6th Gen Interceptor (2007 VFR800FI - RWB)
(Proud Member - 6th Gen Militia - 1st VTEC Battalion)
I tried the bike shops in the greater st.paul mpls area, then moved on too salvage yards.
Now im moving on to salvage in other states. ebay has nothing for that part, im getting desperate now.
Just wondering, does it HAVE to from that make/model? Or would one from another year, etc, work? Is it vacuum operated like many?
Larry
also check with these folks Bike Bone Yard - Motorcycle Salvage Yard Stocking Many Diverse Parts
duffman723 (06-20-2009)
yes, the part is different from the 84 85 models.
that seems to be my luck.
still looking for some help with this. at an idle the bike kills, but if given some fuel, wham bam thank you mam. I just don't want to keep the throttle open at a red light.
I just need a new petcock
Think it would be the same as 86-87 700?
HOOK'EM HORNS!!!
VFR 87 700f2 with
hand made tail section
"There are chords in the hearts of the most reckless
which cannot be touched without emotion. Even the
utterly lost, to whom life and death are equally jests,
there are matters of which no jest can be made."
Is there a way to modify the 84 85 petcock to fit the 86?
Also, great white, your bike looks good, what did you do to it?
Oh, just a little of this and a little of that:
http://vfrworld.com/forums/first-sec...85-vf750f.html
sorry man she cant be saved you should just get rid of her buy a new bike
oh sorry thats Q-mans job![]()
you might be able to try this but not sure if it will work.... Pingel Fuel Valves
Exactly what is wrong with the petcock?
Jamie D has a trick for getting them to work. I can't remember what it was right now, but it involved modifying a diaphragm or something like that...
tried that trick, but it sounds like its gummed up from inside somewhere.
ive read that if rust has gone through the petcock it will pit the insides and buildup will occur .
I have a friend doing the work, he got a gravity fed lawnmower tank to work no problem.
If I could convert this tank to a gravity feed, then my problems solved.
The vacuum is the problem
Yep - Here it is:
Daugherty Motorsports - Motorcycle Suspension Performance and Modification
Just some carb cleaner should fix that up. Are you sure that you modified the valve completely per the instructions in the link above?
FYI - your bike was gravity feed from the factory. The vacuum line is not a fuel pump, it's a safety device. I'm pretty sure it's your diaphragm that is causing your problems. Go back and check my site again to make sure that you've properly modified the valve and I think you will be all set.
I've got one from an 86 500f. are you still in the market?. go ahead and send me a PM if you still need it.
