I'm all set to install some bar ends on my '84...but what's this? The ends of the stock bars are solid. WTF?
Has anyone had any luck drilling or somehow hollowing them out to install bar ends? Thanks in advance.
I had the same problem, I took mine, cut them flat, and used a rubber cement to glue them in. I used blue painters tape over the caps intil they dried.
That;s because the stock bars have factory style "bar ends".
They're solid to move the vibraton frequency to a range where it won't "buzz" your hands...
Yeah I drilled and tapped the stock clip-ons for bar ends 7/8" diameter the holes were 3/4" deep no problem. A little extra weight feels good.
I just cut my bars down. The early VF's use the long grips, I switch to more modern style grips. When you cut off the excess bar length you also cut off the weight inside. That leaves a nice hollow bar that is perfect for use with the standard bar ends.
Here's what it looks like. Please forgive the cheesy carbon look bar ends, that's all my dealership had that day besides blue and yellow:
Jamie,
Can you detect a reduction in vibration?
Jamie, you need to brush a little Vaseline on those switches to freshen them up!
Yeah, those pictures were also a before/after thing as well. The left side I've coated with a special bearing grease that I use. I like how it turns out because the grease is black and it helps by almost dying it. Those plastic pieces are really bad, so I don't think anything is going to make them look 'good' again.
