Results 1 to 2 of 2
Thread: 86 VFR700 starting trouble
    Jul 2009
    Redondo Beach, CA
    '86 700F
    Helloooo,
    Bike's having issues; specifically, it will crank forever and won't start. Doesn't seem to matter if it is cold or hot, choke is on or off. The problem only started after I turned the gas valve to reserve two weeks ago. It was the first time I turned it to reserve since I got it two years ago. When it starts, it's totally fine; she runs great. Randomly it just won't start. Putting the valve to reserve seems to work sometimes to get it started, but then I'll turn it to on. Sometimes when I turn it to reserve or off gas will start to leak out of somewhere, looks like from somewhere underneath the tank.
    Any thoughts?
    Nick
    Uber Guru squirrelman's Avatar
    Jul 2006
    Barf-a-load, ny
    '86 VFR 700Fs (3)/ '97 VFR 750F/ '88 NT 650 HAWK (3)/ '86 Yamaha Radian/ '66 Yamaha YL-1/ '88 VTR 250 / '73 CB 125
    2,288
    Remove the line from tank to fuel pump and blow compressed air into tank (filler cap open) to clear crud from pickup tube.
    Water, rust, other crap collects in bottom of tank; it helps to at least one a year remove the tank, shake it upside down, flush crud out with fresh gas.
    Turning to reserve could have filled the fuel filter (or carbs) with rust flakes or other debris from bottom of tank, so replace the filter, cut it apart for inspection and see what's in your tank.
    Leak from carbs or fuel line needs to be located and fixed.
  1. tachometer trouble
    By ajjr5150 in forum Mechanics Garage
    Last Post: 03-26-2009, 05:59 PM
  2. Trouble starting the engine
    By BigDog750 in forum Mechanics Garage
    Last Post: 12-13-2008, 03:09 PM
  3. 2002 Starting Trouble
    By bobr in forum Mechanics Garage
    Last Post: 07-31-2008, 07:26 PM
  4. gear box trouble
    By SierraVFR in forum General VFR Discussions
    Last Post: 10-07-2007, 09:58 PM
  5. starting trouble
    By snapdragoon in forum Introductions
    Last Post: 09-15-2007, 12:23 AM
