Results 1 to 4 of 4
Thread: '87 turn signal problems
    Aug 2006
    I recently bought an '87 vfr 700 F2. I have been having trouble with the turn signals the last couple of weeks.
    The problem is that sometimes the turn signals do not turn on. I will be riding down the road changing lanes and the turn signals will be working great, then next thing I know i try the signals and they won't turn on. after a while they just come back and i can use them again until the stop working again. I thought that maybe it was a fuse or something, because the first time it happened i checked the fuses and pushed them in a little bit, i don't really think they were loose, but they moved a bit. For the next few days it worked great without a single problem, but this morning it happened again. I checked the fuses again and this time wiggling them didn't help anything.
    Has anyone else had this problem?
    If so, What was the cause and how can i fix it?
    If not, any ideas about what could be happening and what i can do to fix it?
    Senior Member MrJoelieC's Avatar
    Aug 2006
    Milford NH
    2002 Honda Intercpeter VFR800 1985 Honda Intercepter VF700F(sold)
    273
    20 year old bikes often have these kind of squirly issues. I'm willing to bet there is some corrosion in the switch itself. You could try dissassembling the switch assembly as mutch as you can and spray some silicon on the contacts to clean and lube them...
    I'm slowly discovering I may have to do this to my kill switch... At foirst I was suspecting that one or both of my igniter boxes were causing a "hard to start" situation... but I soon discovered that if I wiggle/push on the kill switch I hear a click like it's making contact finally and boom it starts right up... so for the last 3 days I have been experimenting with not using the kill switch to kill the moter but use the key instead.... So far I have yet to have a dificult start situation....
    Cheers!
    MrJoelieC
    Proud Member - Sixth Gen Militia - 1st VTEC Batallion
    Never underestimate the power of human stupidity...
    Aug 2006
    thanks for your reply. I was hoping that i wouldn't get responses that said i should take my bike apart since i am in no way mechanically enclined. I also have no manual or anything that would tell me how to go about this.
    Senior Member tbones86's Avatar
    May 2006
    N/W Central Wisconsin
    86' VFR700F 06' CRF50 06' PW80 98' RT180 2000 Ski Doo Grand Touring 700 94' Polaris Super Sport(sled)
    674
    There's only one way to learn & I agree that it may be your switch assm. I don't know exactly how different the F2 models where other that the instrument cluster but some OE's where found of putting goofy little blinker timers inside their fancy instrument clusters around that time frame,may be an issue but I can't say if Honda did any of that.
  1. gen 4 turn signal stiffness
    By GoForARide in forum Mechanics Garage
    Last Post: 09-05-2009, 05:52 PM
  2. bad turn signal switchs on '96
    By amboyna in forum Mechanics Garage
    Last Post: 10-13-2008, 11:12 AM
  3. 84 vf750f turn signal problems
    By airgreesemonkey in forum Mechanics Garage
    Last Post: 06-21-2008, 04:41 PM
  4. 84 vf750f turn signal problems
    By airgreesemonkey in forum 1st & 2nd Generation 1983-1989
    Last Post: 06-02-2008, 08:34 PM
  5. '87 vfr turn signal problems.
    By ichi in forum Mechanics Garage
    Last Post: 10-06-2006, 11:34 AM
