Go Back   VFRworld > Motorcycle Articles > Specifications > 1st & 2nd Generation
Old 01-01-2008, 10:32 PM   #1 (permalink)
Last Online: 10-11-2008 05:05 AM
vfr won't start either
Hi guys,
Got myself a VFR400 a few months back. So far I'm loving it, plenty of power for my level of riding. It was a jap import only 21,000kms on the clock, and had a full engine rebuild 5,000km ago (previous owner). I had it fully serviced about 2 weeks ago, they changed all fluids, balanced the carbs etc..
However just recently I was riding a short distance home, I was taking it easy and keeping the revs pretty low. It was all going fine until I tried revving it over 5k, it just had this huge flat spot and wouldn't rev properly. Few hundred meters later it sounded like a tractor and had no power, I had to pull over and take it on foot. At first I thought I'd blown a head gasket, but now I'm thinking it's a fuel problem. On the opposite side to the fuel on/off/reserve switch there is a small cylinder which seems to have a vacuum line attached to it. I started the bike and pulled this line off and it started revving perfectly again. There are two small pipes coming out of this cylinder and attaching the vacuum tube to either one didn't seem to make much difference, it was idling fine. So I rode the bike home, but now I can't even get it to start. Anyone have any ideas what it could be?
Sorry for the long post.. and I appreciate anyone who bothers to read it.
honk is offline   Reply With Quote
Old 03-19-2008, 11:48 PM   #2 (permalink)
Last Online: 03-20-2008 12:08 AM
on my vf500 that vacuums tube sucks and makes gas go into the carb
your bike will still run while your carb is full of fuel attack it and try the starter for about 10 seconds it should refill the carbs and if not put at least another gallon of gas into the tank.
other then that its a rare bike I wish I knew more.
I have had to pull the carbs off mine about 30 times not I think I might have a leak in the seals although its still rideable and runs fast it idles funny. dont work on anything that rubber in the cold it will break.
madpantsdome is offline   Reply With Quote
Blackbird to a VFR – a daily, performance riding and touring perspective two4one General VFR Discussions 23 05-17-2008 04:10 PM
Re: vfr Digest, Vol 38, Issue 21 VF/VFR Mailing List 0 05-13-2007 10:18 AM
96 VFR will not start please help concorddesk Introductions 20 04-21-2007 08:57 AM
VFR Discontinued/Replacement? CycleWorld story David Thompson VF/VFR Mailing List 7 11-23-2006 10:04 AM
RE: vfr Digest, Vol 29, Issue 22 Quint A Marcaletti VF/VFR Mailing List 2 08-16-2006 04:08 PM
