i have a 99 800 and im trying to switch out the headlight bulbs. i know they are h4's but everytime i pick up a set of h4( ive tried pilot, and sylvania silver stars) they dont line. any ideas or help would be great. thanks
thats what i thought to but the two bottom prongs that stick out are more at a 45 degree angle rather then mine which are more on the sides say at a 30 degree angle. id like to put h.i.d.'s on it like some 8000k series. i guess the stock bulbs will have to do.
Just bend or break of the bottom tabs. Did mine and they work fine.
There is an adapter you can buy, but you don't need it.
'00 Interceptor
Sargent seat - HeliBars - Yoshi pipe - ZG ST - K&N
5th gens are NOT standard H4's. Honda modified them slightly and you either have to bend the tabs or buy an adapter to make the standard H4 fit. 6th gens however they got smart on and gave us standard H4's.
If you're looking to actually see and not show off, 8000K HIDs are useless as Viffer said. 4300K-5000K will give you the best light for actually seeing.
See this: An explination of Kelvin Temperature and where our 5500K Life-Lite lamps measure on the Kelvin Temperature scale
And this: http://www.ddmtuning.com/images/prod...condary/38.jpg
Hope all this helps.
hey good info guys im sold on the 5000k.
if you dont want to bend the tabs on your bulbs someone makes adapter plates available on ebay to fit standard H4 bulbs.
