Results 1 to 9 of 9
Thread: engine vibs at 6-7K rpm
    Sep 2009
    Biggleswade
    1999 Honda VFR800Fi 1996 Yamaha Thundercat
    Hi
    I've recently bought this 99 VFR800fi with 36K miles on the clock, performing
    great so far but I do get an irritating engine vibration/harshness between 6K-7K rpm.
    below and above that fairly smooth. Is this normal for this model.
    I have synced the starter valves but made no difference, I wonder if the
    the throttle bodies need syncing. Before I take it apart just checking this not a normal characteristic.
    Member jobvfr's Avatar
    Jul 2008
    Princeton NJ
    2001 VFR800 1998 Triumph Sprint 900
    Hey that sounds just like mine, except mine gets rough around 5.5k. It's allways been there, so I thought it's just a characteristic.
    Jobvfr
    Senior Member powderrecon's Avatar
    Oct 2007
    Seattle & Whistler, BC
    1996 VFR750
    366
    Tightening the engine mount bolts is always an option if it has not been done before.
    Uber Guru CandyRedRC46's Avatar
    Feb 2009
    Key West Florida
    2007 Honda VFR800 .... 1993 CB750 NightHawk
    1,062
    valve tolerance inspection/adjustment?
    Sep 2009
    Biggleswade
    Thanks for the suggestions. I will check the engine bolts. The previous owner also had to have a Motad ss downpipes dealer fitted. This because the orginal pipes had rotted through shortly after the sale and there was some resistance by the dealer to replace them, so there was reluctance to do the work. ( not a good sign).
    I not sure if the engine had to be dropped to install them.
    It would be interesting if other members noticed a vibration patch appearing when aftermarket dowpipes are fitted.
    The valve shims are due for inspection so that needs to be done. Still deciding whether its worth the time and effort to do it myself or get known good mechanic to do it.
    I know both rads need moving to get at the heads.
    Anyone done the shims - and did they need adjusting after recommended number of miles. A honda dealer will want over £150 but a least I may get a experianced mechanic to notice what is normal or abnormal.
    Member- VFR Brotherhood
    John451's Avatar
    May 2004
    Sydneys South, 8 minutes from the RNP
    '99
    1,563
    Quote Originally Posted by kelv124 View Post
    I've recently bought this 99 VFR800fi with 36K miles on the clock, performing great so far but I do get an irritating engine vibration/harshness between 6K-7K rpm below and above that fairly smooth. Is this normal for this model.
    Defendant on your sensitivity or how bad could well be normal, my '99 also has a mild period of harshness between 6-7k but sublimely smooth above and below. The '00 Gen5 Mk2 have weighted pegs to quell the peg vibration from this range.
    Sep 2006
    Central New Jersey
    1998 VFR
    245
    Quote Originally Posted by powderrecon View Post
    Have you (or anyone for that matter) done this with any measurable seat of the pants results? Please let me know because I never knew this might be a potential problem. I need to check the shop manual when I get home tonight! Thanks for the insight on this.
    Feb 2009
    Key West Florida
    1,062
    ive got the motads on my bike. though they were a bitch to install, you do not drop the engine to install.
  9. #9
    Junior Member Crashy's Avatar
    Mar 2009
    Last time I got a vibration around 6K RPM I popped the seat and repacked the tool kit, also used pieces of bicycle inner tube to insulate any other loose parts and it all went away.
    I always start with the cheep fix first.
  1. Need a new engine!
    By stopping_power in forum 1st & 2nd Generation 1983-1989
    Last Post: 09-02-2009, 05:22 PM
  2. Need to know age of engine
    By jammy in forum General VFR Discussions
    Last Post: 04-27-2009, 02:29 AM
  3. The V5 Engine.
    By pjvtec in forum General VFR Discussions
    Last Post: 01-10-2008, 09:58 PM
  4. 06 Engine lag ????
    By k9style00 in forum 6th Generation 2002-2009
    Last Post: 06-20-2007, 07:41 PM
  5. engine oil
    By eddie cap in forum Mechanics Garage
    Last Post: 05-14-2007, 01:46 PM
