Go Back   VFRworld > VFRworld Forums > General Discussions > Anything Goes
Old 11-20-2008, 09:45 PM   #1 (permalink)
twowheelracer's Avatar
Last Online: 01-06-2009 09:17 PM
My Ride: 1983 VF750F
Oil Mod
Has anyone installed one of the holeshot oil mod kits on a first gen. VFF? If so was it stright forward or was there a lot of little issues along the way?
And by the way Interceptors Kick A**
twowheelracer is offline   Reply With Quote
Old 11-20-2008, 10:30 PM   #2 (permalink)
derstuka's Avatar
Last Online: Today 08:32 PM
Did a quick search on here. Look at the thread below.
Suggestions on which oiling mod to go with?
~Jason
1998 VFR800
ZG Double Bubble
Oxford Hot grips
BMC Air filter
Knurled Aluminum Footpegs
The Following User Says Thank You to derstuka For This Useful Post:
twowheelracer (11-21-2008)
Old 11-21-2008, 09:05 PM   #3 (permalink)
tried the link
Thanks for the post I tried the link but could not get anywhere with it I'll see if I can get to the site another way. And thanks again there was alot of diff. ideas. Sorry your link got me to the thread I just think the link that was on there was old
Old 11-23-2008, 02:35 PM   #4 (permalink)
Good Day All! After going over this thread ( Thanks DerstUka) anybody With a Holeshot top end oil kit And anyone with a Dave Dodge topend oil kit With any comments would be helpful
Old 11-23-2008, 06:27 PM   #5 (permalink)
JamieDaugherty's Avatar
Last Online: Today 03:19 PM
Check out my site for details on the installation of the oiling modification. Also check out my FAQ section for some additional information concerning the types of kits available. Feel free to e-mail me with any questions!
The Following User Says Thank You to JamieDaugherty For This Useful Post:
twowheelracer (11-24-2008)
Old 11-28-2008, 09:49 PM   #6 (permalink)
Well after checking out all the method to do the oil mods I'm going to do the drill and tap approch for a few reasons. 1) the job when done (right) looks like its supposed to be there not an after though. 2) The post from you guys helped out tons, Jamie daugherty for his web site. Derstuka for pointing me to the thread
Old 11-29-2008, 08:31 AM   #7 (permalink)
Keep in mind that you'll want a metering orifice in the system to regulate the flow. Depending on the style/size/brand of hose and fittings you use it might not be necessary, but at a minimum you'll want to measure pressures to make sure that you don't have a potential problem. When building a system yourself, the actual size of this orifice will need to be determined by trial and error.
It's hard to believe that you can have too much flow to the top end, but it's really the bottom end that needs most of the pressure from the oiling system.
twowheelracer (11-29-2008)
Old 11-29-2008, 09:03 AM   #8 (permalink)
Last Online: Today 11:36 AM
My Ride: 83 VF750F 86 VFR700F 01 F4i 05 VFR800 75 BMW R60/6
There seems to be a debate within the group of people who opt for the drill & tap method, some use -4 hose from the gallery all the way to the heads, while others use -4 hose from the gallery and then drop to -3 after the T split.
I went with the reduction to -3. YMMV.
Sebspeed is offline   Reply With Quote
Old 12-14-2008, 12:05 AM   #9 (permalink)
Well I've started the oil mod this evening and it seems to be going well no issues as of yet.
Old 12-31-2008, 09:33 PM   #10 (permalink)
OK all was going well until I started putting the carbs on this evening. I noticed coolant setting on the case right side rear head. ( BUMMER) Looked at the honda service manual and to fix this leak I have to remove the engine from the frame ( Lots of work I had not planned on Time And $$$). OK with the engine out and having to replace one head gasket should I also replace the front head gasket? And what else should I do with the engine out? Thanks for any help
Old 01-01-2009, 08:51 AM   #11 (permalink)
I'm confused: what makes you think it's the head gasket? Head gaskets almost never cause an external leak. If you see coolant puddles in the V area this usually means one of the seals for the coolant tubes is leaking. This is fairly common with these bikes, it's understandable considering how hot it gets in there. The seals are special Honda parts but not that expensive. This is certainly not something that you need to remove the engine for!
Old 01-01-2009, 03:32 PM   #12 (permalink)
Well Jamie I'm a worst case kind of guy . Your right on the money with the coolant tube so the fix is easier to do ( see sometime the worst case thing pays off) I'll need to get the Oring gaskets and replace them all. Thanks Jamie for your insights. very helpful..
