Go Back   VFRworld > Motorcycle Articles > How-To Articles > Brake & Tire Articles
Old 10-13-2009, 04:48 AM   #1 (permalink)
Last Online: 10-15-2009 12:12 PM
Exclamation Rear Brake losing pressure
Hi,
I ride a 2002 VFR and have intermittent rear brake failure.
Once in a while the rear brake will go - there will be no resistence and fails to brake. The front brakes are fine.
On its last service I replaced the brake fluid but the problem still came back last week. THe last time it happened I had only travelled 4 miles, and once I powered the bike off and on the brake came back on.
Any ideas would be helpful.
Eamon K.
eamonk is offline   Reply With Quote
Old 10-13-2009, 06:54 AM   #2 (permalink)
02 VFR Rider's Avatar
Last Online: Yesterday 03:03 PM
My Ride: 02 RC 46
is this an ABS bike??
ZG dbl bbl, semi gutted stock exhust
" The Chip " power mod, 19mm tail riser
and cool red grips
02 VFR Rider is offline   Reply With Quote
Old 10-13-2009, 08:12 AM   #3 (permalink)
No, but they are linked.
Old 10-13-2009, 08:27 AM   #4 (permalink)
My Ride: 02 RC 46
the turning the bike on / off is trowing me off, that should have no effect on the brakes.
did you work on the brakes before this problem came up??
and cool red grips
Old 10-13-2009, 11:19 AM   #5 (permalink)
No, this problem happened about 4 times in 2 years. I replaced the brake fluid last May and the rear brake failed last week.
When it happened I pumped it alot but there was no resistence. Then at some red lights - I turned it off for a moment and then back on, and the rear brake worked fine. It still is since then and I have probably drove 200+ miles on it since then.
Old 10-13-2009, 12:41 PM   #6 (permalink)
Average Weird Guy.....
stoshmonster's Avatar
Last Online: Yesterday 03:53 PM
My Ride: '95 Ducati 900ss,'03 Honda VFR800,'04 Honda RC51
Don't know if this will be helpful to you Eamonk,but here's a little info for you. I own an '03 VFR800,and as far as I know there were two warranty recalls on the '03 models because I received both of them. One was for the melting dash wiring harness issue,and the other was for brake failure due to leaking or faulty proportional valves in the LBS system. I completely removed the LBS system from my bike so I never had any problems with it,but my dash wiring harness on the other hand was melted pretty badly. I'm not sure if either of these two warranty issues will pertain to your '02 model Eamonk,but it might be a good idea to take your bike to your local Honda dealer and have them check your VIN number to see if your bike is elligible for any warranty repair work. Warranty work doesn't cost you anything,Honda picks up the bill.
If you want to check the proportional valves yourself for any brake fluid leakage,they're mounted on a bracket that's bolted to the back of the main engine frame. That bracket is located next to the upper rear shock mount in the space between the back of the engine and the rear subfender. It's a very tight fit in there so Good Luck to you.
Remember,you're not braking til your rear wheel's lifting,until then you're just slowing down.
stoshmonster is offline   Reply With Quote
Old 10-13-2009, 12:52 PM   #7 (permalink)
Squidleyous Maximus
reg71's Avatar
Last Online: 11-12-2009 07:54 AM
trace back from the lines on your rear caliper looking for a wet spot. are you finding any leaks? before spending any money, I'd go through the full brake bleeding process just to make sure it's not air bubbles. if you do that and then still have the problem it might be time to talk to your dealer...
Reg71 - Central Coast, CA
98 VFR 800 - 5G Brotherhood
Tags
brakes, failure, rear
VFR800 5th Generation - A Gearhead’s Delinking Brake Saga and the Interceptor SS mello dude Brake & Tire Articles 21 05-28-2009 12:55 PM
Rear Brake Bleeding Question Glockem Fifth Generation 1998-2001 9 11-13-2008 11:06 AM
Rear Brake dragging? woody77 First & Second Generation 1983-1989 0 09-14-2008 01:43 PM
Rear brake -brake light adjust Allan General VFR Discussions 0 08-04-2007 08:48 PM
Brake Dancing michael Riding Advice 6 01-13-2006 02:18 PM
