Go Back   VFRworld > VFRworld Forums > Local Riders > North America > Canada & Alaska
Old 09-05-2007, 08:39 PM   #1 (permalink)
shayne100's Avatar
Last Online: 06-28-2008 03:30 PM
My Ride: 2000 Green VFR800FI
valve adjustment for 2000 VFR
when does it need to get done, how much did it cost, is it something that needs to get done every ?? kms
Thanks for the input
shayne100 is offline   Reply With Quote
Old 09-05-2007, 09:55 PM   #2 (permalink)
derstuka's Avatar
Last Online: Today 08:32 PM
Every 16,000 miles and will probably cost about 500-700 US dollars. It ain't cheap. Depends on the hourly labor rate of your local bike shop. Guy before me had my bike's valves done for about $550 or so I think it was.
You bike is not gonna seize up without it if you don't do it or anything. It will mostly likely just not run as efficiently/cleanly (IF the valves needed adjusting during the check), among other things the longer you push it, and how much they are out of spec.
~Jason
1998 VFR800
ZG Double Bubble
Oxford Hot grips
BMC Air filter
Knurled Aluminum Footpegs
Old 09-05-2007, 11:26 PM   #3 (permalink)
skidvicious's Avatar
Last Online: 12-18-2008 05:22 AM
My Ride: 2001 Honda VFR800 F1
I bought my Y2K when it had 18K on the clock. My mech guru with a very good reputation for his work (ex Honda tech working for himself) recommended a valve check when I got to the 48K milestone. Why so long? Well according to my mech its the typical Honda reliability factor plus the experience this guy has with these motors. And because I dont regularly visit 10K or more on the tacho to regularly, the motors valves arent being worked to the point where more frequent checks are necessary.
So at 48K the valves got checked and all were within the spec tolarances. Cost was about $600 AUS but that also included other work (radiator/clutch/brake fluid flush and replacement) I do the oil/plugs stuff myself.
If you know the bikes service history, when the last valve check was done and dont ride near the red all the time - I reckon checks at 20k intervals would be appropriate. If that pushes your comfort zone a bit and the wallet is happy to support more frequent intervals - go for it!
Did I mention that I love this bike and its bullet proof motor?!!
Cheers!
Skidvicious!
If it 'aint broke - leave it
the hell alone!!
skidvicious is offline   Reply With Quote
Old 09-30-2007, 01:54 PM   #4 (permalink)
nitronorth's Avatar
Last Online: 01-05-2009 02:42 AM
My Ride: 1981 cb750f 1981 cb900f 1982 cb900f 1983 cb1100f 2000 vfr 2006 fjr13
Shane..winter is coming.. you have time to check it yourself..not a big deal to check them....odds are they are in spec as most do stay in spec for a long time..mine has 55000km on it and they are still in spec..BUT i still check them every now and then...Now if they are NOT in spec and you arnt up to pulling the cams and doing it, THEN pay to get it done or learn how. Otherwise save your $$ if they are in spec..
In the meantime its pretty simple on the 5th gen to remove the valve covers and just check the clearance..all the info is on the vfr sites...
give it a try!!
enjoy!
NITRO
YAHOOO!!! I ESCAPED THE #$%#^% PRAIRIES !!!
CHECK OUT MY BIKE AND SNOW PAGES.......
http://www.bcsnowcat.ca
nitronorth is offline   Reply With Quote
Old 12-02-2008, 04:49 PM   #5 (permalink)
ChrisVFR's Avatar
Last Online: 12-21-2008 03:31 PM
My Ride: 1996 VFR750F
I got a 4th gen and i check the valve clearance every 10000 miles. My bike has 56xxx miles it's still within spec.
ChrisVFR is offline   Reply With Quote
Old 12-02-2008, 09:15 PM   #6 (permalink)
MarkBartels's Avatar
Last Online: Today 08:49 PM
My 94 was in spec (perfect) at 17k miles. Shop around, I had mine done by a reputable independent shop and they charged me $170.
"You are either on something or onto something".....The Common Man
MarkBartels is online now   Reply With Quote
RE: vfr Digest, Vol 40, Issue 3 /Chain Maximum Adjustment Joe Speed VF/VFR Mailing List 0 07-04-2007 09:38 AM
RE: vfr Digest, Vol 30, Issue 55 Andrew Bertsch VF/VFR Mailing List 5 09-26-2006 05:38 PM
Subject: Re: Valve adjustment on a'93 VFR750 David Botsford VF/VFR Mailing List 51 04-05-2006 05:32 PM
Valve adjustment on a'93 VFR750 Olivier VF/VFR Mailing List 1 04-03-2006 04:19 PM
16K mile valve check and adjustment jasonhallman03vfr Sixth Generation 2002-2009 3 11-29-2003 09:25 PM
