Go Back   VFRworld > Motorcycle Articles > How-To Articles > Exhaust Articles
Old 12-22-2005, 10:48 AM   #1 (permalink)
Administrator
Last Online: Today 12:24 PM
My Ride: 1994 Honda VFR
Emissions Removal
This is how you remove the extra little goodies that come on a CA model VFR.
Here's what you do:
1. Removed the canister and most of the brackets that held it on. Leave the bracket that's on the left side, as this bracket is also used to hold the lower cowl on. You should secure vacuum hose that runs up to tank vent by fastening it with a zip-tie to the radiator hose. Make sure it is routed so that any fuel that may overflow from your tank does not come in contact with you head pipes.
2. The other vacuum hose that was connected to the canister goes to the Evap Purge Control Solenoid Valve. You might also want to pull the Evap Purge Control Solenoid Valve. That's the barrel shaped valve located on the right side just below the frame beam. It's connected to the canister by a vacuum hose. Just disconnected the solenoid wire (leave that in place) and removed the solenoid. Next trace the line from the solenoid valve back to a 4-to-1 connector that feeds the throttle bodies. Remove this vacuum hose and cap the open hole in the 4-to-1 connector, which prevents air from leaking in. A bicycle intertube cap with a little black silicone works great for this.
Basically, your tank will now be vented to atmosphere and you won't have any of this other crap to clutter up the bike and add weight. Besides the weight, the biggest advantage is that you will be able to access your oil filter much easier. Of course, if you went on a diet it would make a bigger difference in weight.
michael is offline   Reply With Quote
Old 01-02-2008, 10:57 PM   #2 (permalink)
Last Online: 04-07-2008 01:35 AM
My Ride: 1992
Thanks for the advice. I removed the EVAP can and I had a problem with flooding. This must have been caused by the lack of a vent since I plugged the lines. With the lines open the problem seems to have ceased.
Sierra VFR
SierraVFR is offline   Reply With Quote
Decal Removal Neptune General VFR Discussions 7 04-13-2008 05:41 AM
1992 VFR 750 emissions testing kinome79 Third & Fourth Generation 1990-1997 6 12-17-2007 03:58 PM
vfr emissions dockster General VFR Discussions 7 10-17-2006 07:45 AM
Re: Grab rail bolt removal question (Chris Aschauer) Dan Barufaldi VF/VFR Mailing List 0 03-01-2006 03:15 PM
1999 VFR Emissions question Jester Fifth Generation 1998-2001 2 01-06-2004 11:24 PM
