Old 03-13-2008, 12:59 PM   #1 (permalink)
eros88's Avatar
Last Online: 12-14-2008 09:54 PM
Only start in neutral?
Hi everyone-
First of all, apologies for my newbie-ness; I JUST picked up a 2000 VFR, and have the following question: the bike will only start when in neutral. Now I know that some motorcycles are wired to only start in neutral, but from reading the manual and the various forums here, I gather that VFRs should be able to start in gear, obviously given that the clutch lever is engaged.
Any ideas? Other posters seem to think this is a problem with the clutch switch- can anyone explain to me what the clutch switch is, and where it's found? Like I said, I'm a bit of a newbie, especially mechanically.
Safe riding!
eros88 is offline   Reply With Quote
Old 03-13-2008, 01:27 PM   #2 (permalink)
Last Online: 01-03-2009 09:55 PM
My Ride: 1998 Honda VFR800, 90 Honda RC30, 86 Suzuki RG500 (Wolf), 90 Suzuki Katana 1100,
Make sure your sidestand is up.
PorscheBob is offline   Reply With Quote
Old 03-13-2008, 01:44 PM   #3 (permalink)
eros88's Avatar
Yeah, sidestand is up... I typically start in neutral anyhow, but I discovered this problem when I stalled once, and had to find neutral to start back up.
Old 03-13-2008, 01:46 PM   #4 (permalink)
eddievalleytrailer's Avatar
Last Online: Today 06:57 AM
The clutch switch is kinda under the clutch lever. It has 2 wires going to it. To test the switch, disconnect the 2 wires from the switch, and connect them together. If the bike now will start in gear with the sidestand up and the bike in gear (clutch in of course), you got yourself a bad switch. A new one is about 20 clams (or one Pres. Jackson). If the sidestand is down, the bike will only start in N, no matter if the clutch is in or not. Hope this helps.
Proud Member Sixth Gen Militia-1st VTEC Battalion
Old 03-13-2008, 04:20 PM   #5 (permalink)
eros88's Avatar
Great, thanks a lot for the info. I'll try it when I get home tonight!
Old 03-13-2008, 04:28 PM   #6 (permalink)
Most Royal Deluxe Member
Lgn001's Avatar
Last Online: Today 04:43 AM
My Ride: 1983 CB1100F 2000 SV650 2007 VFR
If you can't fix it, I'll take that yellow 2000 off your hands...
Just kidding! Welcome, and congrats! Those yellow 2000's are one of my favorites...
Lgn001 is offline   Reply With Quote
Old 03-25-2008, 04:30 AM   #7 (permalink)
Last Online: 12-11-2008 02:48 PM
My Ride: 2000 vfr800 FiY
There is also a diode located in the main fusebox, quote from the workshop manual...
"The diode is part of the safety circuit which prevents or stops the engine running if the transmission is in gear whilst the sidestand is down, and prevents the engine from starting if the transmission is in gear unless the sidestand is up and the clutch lever is pulled in"
mike_y is offline   Reply With Quote
Old 03-25-2008, 06:36 AM   #8 (permalink)
mikeym's Avatar
Last Online: 11-27-2008 10:43 AM
Welcome to the boards! Nice yellow vfr! I just purchased one too :)
CHRISTIAN SPORT BIKE ASSOCIATION
#953
www.christiansportbike.com
mikeym is offline   Reply With Quote
'96 VRF 750: Engine Won't Start mightyquinn Mechanics Garage 7 10-19-2007 05:51 PM
Re: Won't start... OK, wouldn't start / Eclectical System Voltages??? Mrydr VF/VFR Mailing List 0 02-13-2007 07:53 AM
2000 VFR Interceptor doesn't start vfr2000 Introductions 1 12-21-2006 09:39 PM
99 won't start Bob Chappuis VF/VFR Mailing List 0 10-16-2006 10:04 AM
'99 Wont Start - Help Me! vfrcrazy Mechanics Garage 2 03-03-2004 09:09 AM
