Old 07-15-2008, 01:25 PM   #1 (permalink)
RandyM's Avatar
Last Online: Today 08:17 AM
My Ride: 1999 Honda VFR800, 1972 CB750 Cafe
1999 Fuel Injector problem
Hi everyone, I have a problem with one injector cutting in and out. It goes away when I add concentrated injector cleaner to the fuel but missed a couple of tanks and it seems that it is stuck. Has anyone experienced this before and is there any cure other than replacing the injector.
Thanks for your time.
Randy.
RandyM is offline   Reply With Quote
Old 07-15-2008, 01:38 PM   #2 (permalink)
Britt's Avatar
Last Online: Yesterday 08:56 AM
My Ride: 2001 VFR
I have heard of companies that can test and rebuild injectors after you mail it to them, however I don't know if the savings over buying a new one is significant.
2001 VFR
Corbin Seat, Heli Bars, Givi Smoked Touring Windshield, SOS Priority Plus Taillight Modulator, Blue Sea 5025 Fuse Panel, Symtec Grip Heaters, Stebel Nautilus Air Horn, Throttlemeister, Garmin Nuvi 200 w/ Ram Tank Mount, BLS Peg Lowering Blocks
"If you have a pulse, these four gear-driven cams pushing 16 valves at 10,500 RPM will quicken it." Tim Carrithers, Motorcyclist Magazine - June 2006
Britt is offline   Reply With Quote
Old 07-15-2008, 04:23 PM   #3 (permalink)
hondajt's Avatar
Last Online: Today 06:20 AM
My Ride: 2000 VFR800
have you tried some seafoam? It works wonders on engines with carbon build-up. It is probably worth trying.
2000 Honda Interceptor
Micron exhaust - heated grips - Black Windscreen - Solo Seat Cowl
Merlin 2000 Security System - Real Carbon Fiber Tank Protector
55w white headlight bulbs - white led boogey lights - K&N Air filter
hondajt is offline   Reply With Quote
Old 07-15-2008, 06:06 PM   #4 (permalink)
jobvfr's Avatar
Last Online: 11-10-2008 06:25 PM
My Ride: 2001 VFR800
I haven't seen that problem on a bike, but we get honda cars with either bad injectors or clogged inlet screens. If you remove the injector you can remove and clean the inlet screen (carefully!) and clean it out.
Cutting in and out though sounds like a bad injector or wiring.
jobvfr is offline   Reply With Quote
Old 07-15-2008, 06:29 PM   #5 (permalink)
Last Online: Yesterday 09:13 PM
My Ride: 2000 VFR 800 fi
.....yeah!
Old 08-22-2008, 05:25 PM   #6 (permalink)
RandyM's Avatar
Randy.
Just want to say thanks for the replies and let you know it turned out to be a loose coil wire. The down side is that it cost me 300 bones to figure it out. I will pick it up tomorrow and give it a good run.
1999 VFR800FI
Old 09-15-2008, 02:58 PM   #7 (permalink)
steven113's Avatar
Last Online: 01-05-2009 09:14 AM
when I purchased my 98 it had been sitting for almost 5 years in a shed. the injectors were completely blocked by ald gummed up fuel. before I sprung for new ones I took off the intake system under the airbox and soaked the entire assembly in denatured alchol for 5 days. When I reassembled it to my pleasent suprise it fired over imeadiately and ran like new. I did not have to replace orings to the injectors since they never were seperated from the throttle bodies. if you have the time and the cost of new injectors is something you would like to avoid I would give this a try!
steven113 is offline   Reply With Quote
Old 09-15-2008, 06:46 PM   #8 (permalink)
RandyM's Avatar
Thanks steven113, my injectors were fine, it turned out to be a loose coil wire. I was kind of wierd because it wasn't back firing from unburned fuel, it was just running on three cylinders. I am not sure how the fuel delivery works, I am thinking it shuts down the injector when there isn't a spark but that is just a guess. Anyway thanks for your reply.
1999 VFR800FI
'86 VFR fuel pump relay question Guest First & Second Generation 1983-1989 8 11-23-2008 06:00 PM
5th Gen fuel tank removal for shock install Puma Cat General VFR Discussions 8 01-31-2008 01:18 AM
1999 fuel smell stephenahood Mechanics Garage 2 11-29-2007 07:34 PM
93 fuel pump tbone Third & Fourth Generation 1990-1997 5 07-16-2007 11:55 AM
Stock VFR Fuel Injector Rating? Joe Cargal VF/VFR Mailing List 1 09-11-2006 08:06 PM
