Old 08-04-2008, 05:01 PM   #1 (permalink)
Last Online: 11-14-2008 06:07 PM
My Ride: 2006 VFR800A
16T front sprocket
Whilst in for the 20k service, the chain and sprockets were changed for some nice Renthal sprockets. Always found the standard gearing a bit long, especially around town where it was difficult to be in the sweetspot for a quick getaway. So I swapped out for a 16T front sprocket and... WOW!!! What a fantastic difference! The bike is significantly more alive and the slight pickup in revs (approx +500rpm across gears) has the motor right where you want her when you need to pull out/accelerate out. Great (and cheap) way to boost the day-to-day performance I think.
Adrien
2006 VFR800A
2001 VFR800 Fi-1, RIP
Fi1_Ade is offline   Reply With Quote
Old 08-05-2008, 03:32 PM   #2 (permalink)
tourtim's Avatar
Last Online: 09-26-2008 02:53 PM
intresting..... id lconsider doing it also but wonderin how it affected your fuel mileage? my only gripe would be on road trips....
-94 ninja 250
-01 vfr800
hope to one day buy a
sp-2 rc-51
2000+ model councours1000
klr 650
harley of somesort
tourtim is offline   Reply With Quote
Old 08-06-2008, 04:26 PM   #3 (permalink)
bit early to say as I have only done about half a tank so far and am enjoying the extended responsiveness :) But I've seen about 100 miles so far which is, if anything, slightly better than before! Maybe it's just a case of keeping the engine in a place where the fuel/air mixture is leaner instead of down low where the engine generally runs richer.
In terms of noise, she's still perfect: 80mph and she's around 5200 rpm in 6th.
Adrien
2006 VFR800A
Old 08-07-2008, 08:25 AM   #4 (permalink)
Last Online: 12-01-2008 12:42 PM
My Ride: 1998 VFR800
I did a similar move, but went up 2 in the rear, rather than down 1 in the front. My mileage didn't suffer at all, and agreed, the responsiveness is awesome! Be careful on the "slightly better" mileage, as now you're not going as far as your odometer reads now. Your odometer will now read that you've gone close to 5% FARTHER than you've actually gone. And your speedometer will be close to 10% higher than you're actually going...
Worth it, absolutely.
jkimbro is offline   Reply With Quote
Front Sprocket and Chain Installed! V-FouRce Mechanics Garage 1 03-06-2008 03:21 PM
Front / Rear Sprocket Equivalents stewartj239 Sixth Generation 2002-2009 1 09-24-2007 06:36 PM
VFR800 5th Generation - A Gearhead’s Delinking Brake Saga and the Interceptor SS mello dude Brake & Tire Articles 11 05-14-2007 12:10 PM
Front sprocket purchase? crreed67 Modifications 2 05-10-2006 07:09 PM
Drop a tooth on front sprocket - questions? woodcycl Mechanics Garage 1 06-18-2003 03:41 PM
