Last Online: 10-03-2008 04:25 AM
My Ride: '98 FiW - Jet Black
bizarre dash light function
Hi Folks,
I'm new on here, and to biking generally... as my first motorcycling conquest I purchased a '98 FiW... in Black, it's a lovely bike, I'm using it daily to the tune of around a hundred miles... (hence buying such a big bike to start out with before anyone says anything) I am however, experiencing some bizarre behaviour and was wondering if anyone else on here had seen this before and could shed any light / suggestions... Last week one of the tail light bulbs went on me... the normal tail light element had blown. The odd thing was that suddenly I started to see the indicator lights and the full beam light on the dash start to glow dimly. This is accentuated when I indicate, as in normal light it looks as though i'm indicating the opposite way! This only happens when I have the lights on, sidelights, dipped or full... makes no odds. I swapped the tail light bulb with a rear indicator bulb as they are the same... so I had all my lights working, and got replacement from halfords. Trouble is, with the new bulb in and working properly. I'm still getting the weirdness on the dash. I have checked all the connections at the front and rear lights for corrosion and proper contact. I have also cleaned the main ground to the frame, which has made no difference... Anyone got any other ideas? Like I said, I'm a novice, so any (sensible) suggestions would be greatly received! |
Last Online: Today 06:20 AM
My Ride: 2000 VFR800
The R/R can cause all sorts of odd problems like this. I would replace it and do the mod from wiremybike.com
2000 Honda Interceptor Micron exhaust - heated grips - Black Windscreen - Solo Seat Cowl Merlin 2000 Security System - Real Carbon Fiber Tank Protector 55w white headlight bulbs - white led boogey lights - K&N Air filter |
funny you should say that...
The R/R was replaced about 2 weeks before this problem began...
I've been on the phone to the dealer that replaced it and they seem to think there could be some corrosion on the circuits behind the dials... Is that likely? ![]() |
Last Online: Yesterday 09:13 PM
My Ride: 2000 VFR 800 fi
Possible, but I don't know...
I would start checking voltages at key connections. Even though the r/r was changed, it may still be an issue, or the old one caused damage that was not fixed.
Shop Steward:Chat Hooers Union, Local 151 |
Last Online: Today 12:43 PM
As Drewl noted, I would start testing voltages. Test off of your battery at idle, and at 5k or so. Also, you said the R/R was changed, but how about the stator? That could be your problem as well. Be sure that the connectors were not damaged (melted/burned) going into the R/R either.
Last Online: Yesterday 10:11 PM
My Ride: 2007 25th RWB
I've read a bunch of threads about reported electrical problems and they usually come up after an R/R is replaced or the warranty work is done or after a dealer has touched the bike
. Check all your connectors as well your voltages and make sure the wires that go into the connectors are actually tight inside. The connectors could be connected but if the wires aren't locked in the connectors then they may not be contacting properly.
. Proud Member - Sixth Gen Militia - 1st VTEC Battalion |
cheers guys, I'll have a look and see what I can discover, I'm guessing you mean I ought to check the connctors for the R/R as well as th circuits that manifest the problem...
I'll have a go any way... thanks again... |
Last Online: 11-10-2008 06:25 PM
My Ride: 2001 VFR800
bulbs
I noticed you said you swapped the rear bulbs around, the rear signal bulbs and the rear brake/tail bulbs are not the same. the brake/tail and the front signal bulbs are the same, but not the rear. (at least not stock)
The wrong bulbs will cause all kinds of havoc. Hope this helps
Jobvfr |
bulb swappage
Yeah, it's probably not clear, but I was out and about when the rear bulb went... all of my bulbs in the rear light housing happened to be the same so I swapped the busted stop/tail over. Then when I passed a parts shop on my travels I replaced the duff one with a like for like replacement.
So, for clarity all bulbs are fully functional... whether they are or aren't stock I'm not qualified to say, but as the bike's ten years old, unlikely to be stock IMO. Besides, the problem only seemed to arise after the bulb busted... Anyway, looks like she's going to have to go get taken a good 80 miles to the Honda dealer in the group I bought it through for some freebie work... I can't find her ailment and the Triumph guys seem somewhat confused by her... ho hum. |
| Tags |
| lights |
| Priority Plus Tail Light Modulator Installation | Britt | Modifications | 0 | 06-22-2008 05:49 PM |
| Head Light Issue | Tophurious | First & Second Generation 1983-1989 | 1 | 06-12-2008 07:22 AM |
| Tail light / license plate light / fender eliminator mod ??? | Miketegra | Modifications | 10 | 01-09-2007 10:26 PM |
| 2002 VFR LED brake light addition / mod | fh | VF/VFR Mailing List | 0 | 06-07-2006 07:43 PM |
| '98-'01 tail light / alternate plate light | mccasksl | Mechanics Garage | 1 | 06-19-2003 02:44 AM |
