Old 08-31-2008, 01:06 AM   #1 (permalink)
Bard's Avatar
Last Online: 09-09-2008 11:17 PM
My Ride: VFR 800 Fi 1999
Send a message via ICQ to Bard
Knocking from the Clock
Hi everybody, I ride VFR 800 5th Gen, red one and I am charmed!
I have the following ask: When I press the clutch handle and start to release it a strange knock is heard from the clock. Or when I hold the handle in middle position this knock is getting frequent. Sounds like a relay .. but I found nothing in the manual. Ideas?
Bard is offline   Reply With Quote
Old 08-31-2008, 03:49 PM   #2 (permalink)
Vee-Ef-Ar's Avatar
Last Online: 11-18-2008 12:36 AM
My Ride: 1998 Honda VFR800FI {Silver}
Hi Bard... playing with the clutch will cause the variable air valve {or flapper valve} to open and close on top of the airbox. Sounds a bit like a ping pong ball inside the airbox.
I sometimes hear mine when slowly releasing the clutch before a green light... pop pop, rumble rumble.
Search for flapper valve for more info.
Oh and welcome to VFRWorld.
Silver
Stock
Bob
Vee-Ef-Ar is offline   Reply With Quote
The Following User Says Thank You to Vee-Ef-Ar For This Useful Post:
Bard (09-01-2008)
Old 09-01-2008, 12:24 AM   #3 (permalink)
Bard's Avatar
I hear it from the clock, not under the tank. And it happens only in gear.
I'll check this valve in the manual.
Old 09-01-2008, 10:14 AM   #4 (permalink)
stephanon2whls's Avatar
Last Online: 11-15-2008 12:42 PM
My Ride: 2000 VFR800
It's definitely the airbox intake flapper valve then.. You just provided the last piece of evidence I needed to be 100% sure.
You see, the flapper is only active while the bike if in gear. It is not actuated in neutral.
The noise sounds like it is coming from the clock because the actuator is under the tank towards the front. The noise is projected forward and reflects off of the instruments.
-Stephan
stephanon2whls is offline   Reply With Quote
The Following User Says Thank You to stephanon2whls For This Useful Post:
Bard (09-01-2008)
Old 09-01-2008, 12:11 PM   #5 (permalink)
Bard's Avatar
-Stephan
Ok, Thank you very much.
In the manual is written that this valve is open above 5500 rpm, and under 5000 is closed. What is my situation? Something to worry about?
Old 09-09-2008, 01:45 PM   #6 (permalink)
Bard's Avatar
You were right. It is airbox intake flapper. I left the tank and turn on the engine and saw the flapper.
Do I have to worry ?
Old 09-09-2008, 06:15 PM   #7 (permalink)
Nothing to worry about.. all systems operating within parameters.
Re: electrical problem - nothing works but the clock,/ Main Fuse Starter Relay. VF/VFR Mailing List 1 08-18-2008 05:39 AM
Re: electrical problem - nothing works but the clock,/ Main Fuse Starter Relay Area.... mrydr VF/VFR Mailing List 0 08-13-2008 08:36 AM
Re: electrical problem - nothing works but the clock, and thatain't doing so well Thomas Davenport VF/VFR Mailing List 0 08-12-2008 07:06 PM
electrical problem - nothing works but the clock Lee R VF/VFR Mailing List 0 08-12-2008 12:23 PM
Knocking sound, please help kinome79 Mechanics Garage 14 07-24-2008 08:05 AM
