Sprocket Change
I'm considering going up two teeth in the rear when I replace my chain this winter on my 98. I was wondering if anyone has found adverse affects from doing this. Seems to be plenty of rpm there for it. Right now I'm at 5000rpm at an indicated 75mph and experience no buzz or vibration whatsoever. I know my rpms will go up but is there any buzz or vibration associated with this change? I would love to get the added acceleration with this change but I don't want to sacrifice any ride comfort.
I FREAKING RULE!!!
Last Online: 11-19-2009 11:52 AM
My Ride: 2001 & 2000 VFR800fi
Re: Sprocket Change
I find that my bike vibrates the least at about 6000-8000 rpm. You should have no problem whatsoever with this change. I have not done this mod yet but its on my list, right after new tires. I plan on +2 teeth in the rear with a DID x-ring chain. I ride with a guy who has a 2002 and he went +1 in th rear and he was very happy with the change. He did it specifically to be able to outrun my 00. He should have gone +2, he can catch me but we run neck and neck. I think this VTEC nonsense should be dumped on the next VFR.
8) RIDE WELL 8) HWORTH
Evaluator/Instructor Side Sitting Switch Monkey Motorcycle Safety Foundation RiderCoach USAF Sport Bike Coach Stupid Hurts & Stupid Kills. Don't Be Stupid. ATGATT www.rockthegear.org 2001 VFR800fi Italian Red (Hers) 2000 VFR800fi Pearl Yellow (His) I don't discriminate, I hate EVERYBODY! Fight Communism, Free The People's Republic of New Jersey!!! RIP TSgt Christopher D Rey 1 Apr 1968 - 28 Aug 2006 |
Re: Sprocket Change
I've got a 1 down on the front & 1 up on the rear...
Loads of low end torque and very quick acceleration.. Still hit 165mph on the speedo (@ almost 11K RPM) Cruising at 85-90mph, RPM's at 6500 or so...vibration not too bad. RF
Red \'99 VFR800fi: &&Yosh RS3 (carbon) \'high-exit\' Slip-on, K&N air filter, 1 down on the front sprocket, 1 up on the rear, RT fork springs, FOX TC shock, Dunlop 208\'s |
Re: Sprocket Change
Yes. I just installed a 45T steel Sprocket Specialists on my 2001. It makes a difference by closing up the ratios between gears. Around town speeds are easier to control as the rpms are a bit higher; Gear change seems to be smoother. The sluggish flat spot area (4.5-5.2K rpm) is diminished because of the lowered overall ratios.
Sprocket was $34. plus $6 shipping. http://www.sprocketspecialists.com/html/honda7.shtml Scott |
Last Online: 10-31-2009 09:27 PM
?Re: Sprocket Change
When you go -1 front and +1 in the rear did you have to change the chain lenght or did the stock 106link chain have enough adjustment?
'01 Yamaha YZ426F With a Bunch of Go Fast Parts '99 Honda VFR800Fi Even Faster than the YZ426F KtchMe |
#7 (permalink) | |
Last Online: 09-20-2009 02:33 PM
Re: Sprocket Change
Better to go into a corner slow and come out fast than go in fast and come out dead. |
Re: Sprocket Change
I though it was 106links.... But anywho.. do you yeally get any benifit from a 520 conversion on a VFR? I thought the limiting factor would be the rear sproket since it's a SSS Arm? Inquireing minds would like to know.
T
#10 (permalink) | |
Re: Sprocket Change
Re: Sprocket Change
Done... -1F and +1 rear... It feels great. It was cold out so I couldn't really see how well it done on my normal twisty roads.. I also Installed a set of DP HH+ Pads up front... A much improvement over stock.
Last Online: 10-23-2009 08:21 AM
Re: Sprocket Change
If at all possible, I would go up on the front to increase chain life and then calculate how many teeth you need to go on the rear to achieve the same ratio.
By decreasing the front sprocket, you're forcing the chain to turn a tighter circle and wear out sooner ;) ;) |
| 5th gen sprocket change? | timwat | Modifications | 17 | 11-29-2007 08:59 PM |
| Sprocket Sizes | vger | General VFR Discussions | 2 | 04-29-2007 08:45 PM |
| Sprocket Change Questions?????? | jb5371 | Fifth Generation 1998-2001 | 20 | 03-15-2007 10:44 AM |
| Rear chain sprocket problems. | smokingmagneto | Mechanics Garage | 4 | 09-09-2006 07:39 PM |
| Sprocket question | Guest | Sixth Generation 2002-2009 | 1 | 08-13-2003 12:46 PM |
