Old 05-16-2007, 12:08 PM   #1 (permalink)
amurch1's Avatar
Last Online: 12-29-2008 04:26 PM
My Ride: '00 VFR
front wheel wobble
does anyone have front wheel wobble between 50 and 60 mph?
amurch1 is offline   Reply With Quote
Old 05-16-2007, 12:11 PM   #2 (permalink)
Bubba Zanetti's Avatar
Last Online: Today 05:51 AM
My Ride: 1997 VFR750F
NO!
Time to have them wheel bearings checked!
Out of curiosity, you don't use a high pressure hose to wash your bike do you? If so, that is a major cause of wheel bearing failure.
When the bike is parked, run your hand over the front tire. If it feels "rippley" then your tire has scalaped and needs replaced. That can cause a wobbly type feel.
And last but not least, check your streeting head tightness.
Some things to try!
BZ
"The average man does not get pleasure out of an idea because he thinks it is true; he thinks it is true becasue he gets pleasure out of it".
-H.L. Mencken
Bubba Zanetti is offline   Reply With Quote
Old 05-17-2007, 08:05 AM   #3 (permalink)
masonv45's Avatar
Check your tire pressure front and rear. Also see if you have any horizontal swingarm movement.
1985 VF700F
Memphis, TN
Old 05-17-2007, 08:38 AM   #4 (permalink)
Sky King
SLOav8r's Avatar
Last Online: 01-04-2009 02:12 PM
My Ride: 1999 VFR 800 / 2000 CBR 1100XX Blackbird
And don't let anyone tell you a steering damper will solve the problem...
SLOav8r
Will fly for food...
SLOav8r is offline   Reply With Quote
Old 05-17-2007, 10:09 AM   #5 (permalink)
amurch1's Avatar
My Ride: '00 VFR
Thank you everyone that reply to my post.
Here's what I've done and found;
I have replaced:
head bearings, wheel bearings, new seals and oil in fork tubes.
result: NONE, still wobble @ 60 - 50 mph.
I found out yesterday that a friend with the same year (2000 VFR) has the same issue. So, this maybe something inherent with that year.
I would like to ask everyone that has a 2000 vfr to lighten up on the handle bars @ 50-60 mpg and see if you get any wobble. this is just a survey of sorts.
thank you
Old 05-17-2007, 04:29 PM   #6 (permalink)
cat0020's Avatar
Last Online: 12-10-2008 12:33 PM
My Ride: Too many to list, never enough.
Have you considered getting the front wheel balanced?
Chances favor the prepared mind
Master your environment, and you will survive just fine.
cat0020 is offline   Reply With Quote
Old 05-17-2007, 04:31 PM   #7 (permalink)
cat0020's Avatar
Is your front tire cupped or worn?
Old 05-17-2007, 04:48 PM   #8 (permalink)
Last Online: 12-29-2008 10:56 PM
My Ride: 00 VFR
Hey Armuch,
Try taking your bike to Milpitas Honda and have them do a CompuTrack analysis of your bike. It could be something as simple as a suspension tweak or a rake and trail adjustment.
I also own a Y2K VFR and early on I also had front end wobble while decelerating. Come to find out I had the rear Suspension set too firm and the front set too soft. I changed the tires and had the suspension setted up and now I am as smooth as silk. Yea!! that is the ticket.
JRotten: many miles riden and many more to ride
Y2K bike
- Race tech forks
- Ohlins rear shock
- Galfer brake lines and pads
- KN filter
- DiD xo chain
- Renthal sprockets
- Corbin saddle/ Bettle bags
- Givi trunk
- Hot grips
Currently using Michelin Pilot Power tires
JRotten is offline   Reply With Quote
Old 05-17-2007, 05:43 PM   #9 (permalink)
amurch1's Avatar
My Ride: '00 VFR
I'm going to reduce rear preload, I'll let you all know.
fornt tire is new, had balance chedked twice.
Old 05-18-2007, 02:21 PM   #10 (permalink)
Sky King
SLOav8r's Avatar
If it's new and balanced inspect it REAL close for a bubble or some other defect. Do you feel any pulsing during braking?
And +1 Milpitas Honda, they're good peeps.
SLOav8r
Old 05-18-2007, 02:24 PM   #11 (permalink)
Sky King
SLOav8r's Avatar
Gets me thinking... is Ye Old Pizza Joynt still around?
SLOav8r
Old 05-20-2007, 09:02 PM   #12 (permalink)
whiplash's Avatar
Last Online: 12-01-2008 08:23 AM
My Ride: 2001 VFR 800
I did and it was wheel bearings.
2001 VFR
Laminar lip for standard screen
Sargent seat w/quick release cowl pins
Polished wheels
DG8 Gear indicator
Custom grips
Vista Cruise
Stem stand (for stereo, GPS, etc.)
VFR matching color tank pad
Custom fairing protectors
Filter Mag for oil filter
License plate locker (storage)
whiplash is offline   Reply With Quote
Old 05-20-2007, 09:10 PM   #13 (permalink)
R.W.'s Avatar
Last Online: Today 11:51 AM
My Ride: 99 VFR
Good thread guys, I notice a little wobble when I take my hands off the bars, had it with the old Dunlops and the new Conti's, it was there with the old suspension and still there with the new suspension, I'll be checking the wheel bearings next weekend......
Member- 5G Brotherhood
Life begins at 45 degrees
R.W. is offline   Reply With Quote
Old 05-22-2007, 11:15 AM   #14 (permalink)
amurch1's Avatar
My Ride: '00 VFR
I do have pulsing during front braking now, what's that about?
I reduced rear preload and had no efect.
Ye Old Pizza Joynt burnt to the ground, that was a big loss.
Old 05-22-2007, 12:44 PM   #15 (permalink)
masonv45's Avatar
Pulsing is usually due to your rotors being warped.
As Cat0020 asked, have you re-balanced your wheels to see if they're balanced?
1985 VF700F
Memphis, TN
Old 05-23-2007, 11:18 AM   #16 (permalink)
cat0020's Avatar
Brake lever pulsing when you apply the brakes usually means that the brake rotor/s are warped, or brake pads have moved out of alignment.
Put bike on centerstand, rotate wheel/s to determine rotor alignment. Pull the calipers to check for brake pad wear.
Warped rotor/s usually do not effect handling, nor should it cause the front end to wobble at certain speed going straight without braking.
Old 05-23-2007, 04:39 PM   #17 (permalink)
amurch1's Avatar
My Ride: '00 VFR
left rotor is warped, ordered galfer wave rotors.
let you know how they work latter.
as for the wheel wobble....it must be the tire, running the new cont attack, did not have the wobble with mich roads.
Old 05-23-2007, 05:41 PM   #18 (permalink)
winaje's Avatar
Last Online: 12-12-2008 12:57 AM
My Ride: 2005 VFR800 in Winning Red
Send a message via ICQ to winaje Send a message via AIM to winaje Send a message via MSN to winaje Send a message via Yahoo to winaje Send a message via Skype™ to winaje
Regarding the wheel wobble at 50-60 mph. I had a similar thing on a bike a few years ago, with a nearly new front tyre. Had the bike shop remove the tyre, and they found that the rubber dust inside had balled up. It's not normally a problem but when the bike is at that speed the weight of the balls was enough to throw the balance out and induce a wobble. As soon as the balls were removed the problem went away.
Hope this helps.
Kind Regards, Will Church
www.d2au.com
6th Gen Militia
1st VTEC Battalion
Click here for info
on Genuine Honda
Carbon Fibre 6th Gen
Meter Panel & Yoke covers
winaje is offline   Reply With Quote
Old 05-30-2007, 09:05 PM   #19 (permalink)
amurch1's Avatar
My Ride: '00 VFR
Hello all,
well the wobble is gone.....turns out it was conti attack. I also installed new wave rotors. so thank you to all that tried to help.
