Old 10-09-2007, 01:27 PM   #1 (permalink)
philly_speed_6's Avatar
Last Online: 12-18-2007 10:16 AM
My Ride: 1986 VFR 700 F2
solo seat cover
I just ordered a solo seat cover and seat latch from evay.
Need help with installing the seat cover...
Attached is a pic... How does the back end match up to the tailight? Does this replace the entire rear fairing?
http://houseofmotorcycles.bikebandit...F2/1986/219809
philly_speed_6 is offline   Reply With Quote
Old 10-09-2007, 02:22 PM   #2 (permalink)
87/700F2's Avatar
Last Online: 05-06-2008 01:19 AM
My Ride: 1987 Honda VFR 700 F2
find the two screws on either side of your seat they should be chrome.you need two take those out. then look at the back of the seat at the very center of the rear fairing there should be a little cut out for the tap on the back of the fairing that you just bought. slid the tap into slot then push down over seat then reinstall the screws that you took out at the beginning they should fit through the holes in the side of your new fairing.if the picture that you have shown is of the actual fairing it looks like thoughs holes may have been broken off. hope this helps you.
87/700F2 is offline   Reply With Quote
Old 10-09-2007, 02:24 PM   #3 (permalink)
it does... the left side is broken but the right side hole is ok.. Thinking I may fab something up with my old busted fairings..
Looks easy... I came across a post that had L brackets and the works... Who knows.
2 bolts.. ok, tough one
Old 10-09-2007, 03:10 PM   #4 (permalink)
87/700F2's Avatar
here is a pic of the seat the yellow 0s are the areas i was talking about.
Old 10-10-2007, 11:06 AM   #5 (permalink)
Thanks again.. .Looks easy enough.
Old 11-26-2008, 06:36 PM   #6 (permalink)
Last Online: 01-03-2009 01:36 AM
Helpppppp! I'm dying over here! I purchased a rear solo seat cowl that I can use on my 1984 VF1000F. My only problems are I am missing the attaching pieces to install this cowl such as the locking mechanisms and the seat strap/bolts. I have researched all parts catalogs but the rear solo seat cowl is not shown. I am in the process of having it painted shasta white and will order the decals from cbdecals.com. Any suggestions?
kmw374 is offline   Reply With Quote
Solo seat options for 87 VFR's.....redo drewr First & Second Generation 1983-1989 9 12-17-2008 10:32 AM
Urgent :eek: clarify hardware needed for mounting solo seat cowl ! Sleepless First & Second Generation 1983-1989 0 09-01-2007 04:04 PM
Sheepskin Seat Cover kitty Gear & Accessories 5 08-30-2007 12:19 PM
Solo seat options for 87 VFR's..... drewr First & Second Generation 1983-1989 1 03-08-2007 09:06 PM
1997 rear seat cover pinballvfr Third & Fourth Generation 1990-1997 4 02-22-2007 10:06 AM
