Last Online: 09-20-2009 12:56 PM
My Ride: 1985 VF 700F
86 VFR700 Starter Problem
I need some help on a 86 700 starter issue, the starter sounds like it is running fine, however it seems like it is not engaging correctly. The starter engages then just starts spinning. Is there a starter solenoid that forces the starter gear into the starter gear? Im going to tear it down this weekend and see what I can see, any help would be greatly appreciated.
Thanks |
Last Online: 10-04-2009 11:49 AM
Sounds like your starter clutch is broken or the springs are wore out.
Typically the springs wear out and need to be replaced. Some have replaced the springs inside with stronger ones. That just galls the inside of the clutch more. If nothing is broken, inspect for any galling. If none, replace the springs with new stock if possible. If there is galling, you will have to replace that part.
1985 VF700F (Parting) 1983 V45 Magna Gone but not Forgotten Memphis, TN SabMag FAQ: http://wiki.sabmagfaq.org/ |
Last Online: 12-10-2007 07:00 PM
put battery on a trickel charger then try to start bike(so u dont drain it while trying to start bike). when it starts that "spinning" get under bike still pressing the start button and bash the starter with handle of a screw driver. any money says it will start. u just gotta hit it hard enough. happened on my 86 every once and a while
#4 (permalink) | |
Last Online: 01-07-2009 02:10 PM
My Ride: 1987 VFR700F2 (well...most of it)
I really think there is something wrong with the actual engaging of the starter, you talk about the starter clutch springs, is this a type of starter solenoid. I have been looking through the manual to see what needs to be done to get it fixed. I really appreciate your input. thank you
it looks like a tiny cylnder . its in front of the bike above the headers. you can see it with the plastics on. good luck
#7 (permalink) | |
Last Online: 11-15-2009 06:03 PM
My Ride: 82 V-45 Sabre
83 VF750F Interceptor
91 XR250L
03 Shadow ACE
07 RWB Interceptor
Last Online: 12-10-2007 09:39 PM
eddie is right. The starter clutch always spins-unlike a car starter. Banging it will do little good and much potential harm. My '86 does the same thing when the temp outside gets colder, i.e. the motor spins but the clutch doesn't catch. When it's warm, never a problem, It's gone on for years like this but has never really failed. Try getting the starter warm(space heater maybe?). In a pinch try running the starter motor for 10-15 sec a couple of times as the heat of the motor seems to help free up the clutch. Worth a try.
#9 (permalink) | |
91 XR250L
03 Shadow ACE
07 RWB Interceptor
The wacking of the solenoid is a solution for a starter motor not turning. Yours is turning. It's just not turning the engine.
Here is a video on how to repair the starter clutch on a V65 Magna. Yours should be very similar. http://video.google.com/videoplay?do...90578350336971
hmm....sounds like I need to bust out the hair dryer :)
exactly, it did not do it when it was warm, however as soon as it turned really cold then it started, on a scale of 1-10, how difficult is it to change the clutch springs
this looks to be a common problem with these things....
I had no issues with my bike when it was warm....I wonder if my wife would let me bring the bike inside for a few hours to warm up.... of course I'll leave it on a tarp, honey, and I won't start it in the house..... ![]() |
#14 (permalink) | |
Last Online: 05-12-2008 05:17 PM
It's common on them. My 86 750 did it. Now if I could only remember what the fix was... was only about 12-13 years ago... I think I just took the gears out and rotated them. Something odd like that. They were sticking and not sliding out to engage when the button was pushed. Just made a racket. I don't recall buying new parts so it must have been something I just had to take apart and tinker with. Sorry to be so vague. Good luck. James.
#16 (permalink) |
Ok... I looked at the vid of the Magna. The VFR is a little different but the video reminded me of some roller pins. I think I rotated them to different locations. Never had another problem. Bike had 42K when I sold it. Wish I had the manual and I could say for sure. James.
#17 (permalink) |
I watched the video, and this is exactly whats wrong with my 86 700. Does anyone make a rebuild kit with all replaceable parts for my 86 VFR700F?
#18 (permalink) |
don't know if you've solved your problem, but I solved mine by storing it in the house....it's been a couple weeks since I posted that, but I finally brought the bike in, and when I rolled it back outside this morning, it started right up!
| starter prob | possum2082 | Mechanics Garage | 0 | 09-13-2007 08:52 PM |
| starter system problem | rpicheme | Mechanics Garage | 3 | 10-01-2006 04:24 PM |
| Starter problem | 1g gsx | Mechanics Garage | 0 | 08-09-2006 08:41 PM |
| starter problem? | Harry Lowrey | VF/VFR Mailing List | 2 | 01-27-2006 01:02 PM |
| vfr700 problem | midnight | First & Second Generation 1983-1989 | 2 | 06-23-2003 07:24 AM |
