Old 12-18-2007, 07:19 PM   #1 (permalink)
synaptik's Avatar
Last Online: 04-03-2008 09:44 PM
My Ride: 2001 Honda Shadow Ace Deluxe 750 1985 Honda VF500F Interceptor
85 VF500F idle ??!!
where should a warm idle for the 85 vf500f be at. mine sits at about 3500 rpm at all times is there a way to back it off a bit lower?
i do have a stage 2 jet kit in it ...
30k miles
valves and carbs recently cleaned and jetted
synaptik is offline   Reply With Quote
Old 12-19-2007, 07:35 AM   #2 (permalink)
masonv45's Avatar
Check your manual, but I'm guessing it should be somewhere between 1100 and 1200.
There should be a black knob under your carbs (probably the right side) that allows you to raise and lower your idle.
Turning the knob clockwise raises the rpm.
It takes only a little turn to change the idle. I think a full turn will lower it about 1,500 rpm.
If you turn the knob and the idle will not lower, then you may have some issues:
1. Throttle linkage binding
2. Brass choke valves not closing completely
3. Bad carb sync (2 carbs pulling the rest up to the high idle)
If the idle constantly changes almost everytime you stop, you need a carb sync.
1985 VF700F
Memphis, TN
Old 12-19-2007, 11:23 AM   #3 (permalink)
synaptik's Avatar
thanks i will look into it ... of course i didnt get a manual yet ... and will be a bit till i get a shop manual prob a clymers ....
1984 750F Idle issues, help needed ahoyboyhoy Mechanics Garage 9 09-28-2007 08:40 AM
Re: Death by Electrical.... or is it? HELP! / VDC Readings OK,Low Idle?? Mrydr VF/VFR Mailing List 0 05-10-2007 07:56 PM
RE: idle speed - some technical answers stephanon2whls VF/VFR Mailing List 0 06-23-2006 03:07 PM
Re: idle speed ?? Dan Barufaldi VF/VFR Mailing List 10 06-22-2006 04:10 PM
RE: idle speed Dan Barufaldi VF/VFR Mailing List 1 06-21-2006 01:46 PM
