Old 09-04-2003, 02:03 AM   #1 (permalink)
Last Online: 12-31-1969 05:00 PM
Send a message via ICQ to Mike_C.
1983 VF750F Wheel Conversion???
I have done a few searches and have found quite a bit of info on the 86-87 VFR's, but has anyone ever converted an '83?? I still have the factory 37mm tubes, 16" front, and 18" rear. I was looking at putting new tires on and found that my current choices pretty much suck so....... From what I have read, it sounds like the F2 trick may work, but if I do it should I bite the bullet and do the tubes, wheels, swingarm, shocks, and brakes? Let me know what you guys think, and if you can point me to more info that would be cool too.
Thanx,
Mike
Mike_C. is offline   Reply With Quote
Old 09-04-2003, 05:33 AM   #2 (permalink)
Last Online: 12-31-2008 09:23 AM
My Ride: '90 RC30 clone; '94 CB1000, '99 CB750, '06 599
Re: 1983 VF750F Wheel Conversion???
Here's the link to the wheel conversion: http://www.one-ring.net/vfrfaq/WheelFAQ.htm
I have an extra set of F2 forks, wheels, and brakes if you are interested. $600.00 for the lot
'94 CB 1000, Power Commander, Vance & Hines full system, Ohlins rear shocks, LED tail light, Thurn LED mirrors.
'90 VFR with Staintune high mount and Thurn RC30 replica body kit,. CBR900 forks for the RC30 look on the cheap.
'99 CB750 Nighthawk
'06 599, CRG levers and bar end mirrors, frame sliders, Rizoma concial handlebars, adapters, and grips, LED signal and tail light conversion, whacked rear fender.
Gave the Buell to my god-daughter; wanted her on something slow, heavy, and loud!
waldrm is offline   Reply With Quote
Old 09-04-2003, 05:41 AM   #3 (permalink)
Thanx for the reply. I had already found that link from one of my searches, but it is definitely a good source of info. Basically then, the mod for an 83 is the same and I can do it following the info that I have found so far. As far as your parts, I think that I will shop around a bit. I have been bookmarking stuff on eBay and I think that I may go that way, but we'll see.
Thank you,
Mike
Old 02-27-2008, 10:07 PM   #4 (permalink)
Last Online: Today 11:39 AM
My Ride: 83 VF750F 86 VFR700F 01 F4i 05 VFR800 75 BMW R60/6
Mike, unless you have access to a machine shop(or have a friend that does), look up a member here named Jamie Daugherty. He can make the necessary spacers for you. His website is www.daughertymotorsports.com
Sebspeed is offline   Reply With Quote
Old 02-28-2008, 05:46 AM   #5 (permalink)
JamieDaugherty's Avatar
Last Online: Today 07:11 PM
Just to clarify - it's more than just spacers that are required. There is machining that needs to be to done to the sprocket carrier and the speedometer drive hear housing. You also need a new caliper bracket for the rear. There are more details on my site, if more information is needed shoot me a PM.
Seriously Considering the F2 wheel conversion... Outlawz24 First & Second Generation 1983-1989 47 07-15-2008 11:27 AM
86-87 Wheel Conversion templar VFR wiki 0 05-10-2007 12:05 PM
Original 1983 VF750F vf750orig Introductions 2 02-11-2007 01:46 PM
87 Wheel conversion Todd Hamilton VF/VFR Mailing List 2 01-20-2006 11:43 AM
87 wheel conversion info needed pls rc36ride VF/VFR Mailing List 2 01-20-2006 11:43 AM
