'86 VFR fuel pump relay question
On my '86 VFR700, the fuel pump didn't seem to be working as it was starving for fuel. I could hear it "pop" just once when I turned on the ignition and that was it. I unplugged the fuel pump relay and used a jumper wire as outlined in the service manual. Now when I turn on the ignition, the fuel pump runs like crazy "pop pop pop" ect. and the bike runs great.
My question is this: Do I have to use the relay? Will my fuel pump burn up if I don't replace my relay and just use the jumper wire? Just what does the fuel relay do anyway?? Thanks, Ed |
Last Online: 11-10-2009 09:27 AM
My Ride: 1987 Honda VFR750FH (sold), 2000 Honda VFR800Fi (soon in garage),
1986 Suzuki GSX550E (wifes)
Re: '86 VFR fuel pump relay question
It stops the fuel pump working when the ignition is on but engine not running. So there is a risk the cabs can bleed ower.
Last Online: 11-18-2009 07:17 AM
My Ride: '90 RC30 clone; '94 CB1000, '99 CB750, '06 599
Ed, look at your fuel pressure sensing switch as well. The relay allows the switch to be run with smaller gauge wire; notice that the leads from the relay to the pump are heavier than the one to the pressure switch
'94 CB 1000, Power Commander, Vance & Hines full system, Ohlins rear shocks, LED tail light, Thurn LED mirrors. '90 VFR with Staintune high mount and Thurn RC30 replica body kit,. CBR900 forks for the RC30 look on the cheap. '99 CB750 Nighthawk '06 599, CRG levers and bar end mirrors, frame sliders, Rizoma concial handlebars, adapters, and grips, LED signal and tail light conversion, whacked rear fender. Gave the Buell to my god-daughter; wanted her on something slow, heavy, and loud! |
Sorry, Ed, but when you said fuel pump relay I was thinking VFR800 with FI. Don't think your bike has a fuel pump; it is gravity fed from the petcock on the left side of the tank. Check your system for blockage or pinched hoses; especially the screen inside the tank on an older bike.
All VFR:s do have a fuel pump!
Last Online: 11-19-2006 11:06 PM
By the way Kenny, the 1986 Vf500f is gravity fed, as in NO pump. Just FYI. I am an owner. Coincidently, the fuel petcocks for 84-85 are different than 86 too. Again, just FYI.
| The Following User Says Thank You to 6ft5inch For This Useful Post: | jonnywishbone (03-26-2009) |
Last Online: Today 06:40 PM
My Ride: 86 VFR750 00 RC51 07 CBR600RR
i have an 86 750 and the fuel pump does not run like that of a fuel injected bike. Mine just clicks a couple of times when the ignition is turned on and that's it. I don't really think your pump is bad if it runs when you jump it. Is there a fuel filter on the bike? That's the first thing i'd replace.Can you run the bike from an alternate fuel source using the pump? Just run a line from the inlet side of the pump to a gas jug and see what it does. Does fuel flow freely from the tank with the fuel line disconnected from the pump?
Last Online: Today 05:48 PM
My Ride: '86 VFR 700Fs (3)/ '97 VFR 750F/ '88 NT 650 HAWK (3)/
'86 Yamaha Radian/
'66 Yamaha YL-1/
'88 VTR 250 (2)/
'73 CB 125
i've been using the jumper wire on my '86 700 since the relay failed in '91 with no problems.
just be sure to turn the key to OFF if the bike happens to go on its side.....
" Goin' to Hell in a bucket, but at least I'm enjoyin' the ride....... " "It's no use, mate, the bottom's fallen out......." |
Last Online: 11-03-2009 12:59 AM
Old thread, but I don't have a manual, and my relay appears to not be working. Has voltage going in on two wires, and none coming out to fuel pump. Where do I place jumper to make it run?
#11 (permalink) | |
Last Online: Today 01:44 AM
My Ride: 07 RWB
Last Online: 11-09-2009 01:03 PM
My Ride: 1984 Honda Interceptor 500
So your saying i could use an 86 gas tank on my 84 vf500 if i short the fuel relay bypassing the fuel pump?
| RE: vfr Digest, Vol 29, Issue 22 | Quint A Marcaletti | VF/VFR Mailing List | 2 | 08-16-2006 04:08 PM |
| No Subject | Jeff | VF/VFR Mailing List | 0 | 08-09-2006 06:14 PM |
| Re: vfr Digest, Vol 28, Issue 12 | David Thompson | VF/VFR Mailing List | 0 | 07-17-2006 08:00 AM |
| Re: Question from a new VFR owner about R/R / Onboard VOM...... | Mrydr | VF/VFR Mailing List | 0 | 06-13-2006 10:27 AM |
| 5th gen fuel pump wanted | John Harrison | VF/VFR Mailing List | 5 | 01-11-2006 11:59 AM |
