Old 06-19-2008, 09:52 PM   #1 (permalink)
XFF
Last Online: 06-20-2008 06:27 PM
VF1000F when hot problem
Hello,
Just purchased an 84 VF1000F project bike. Most of the problems are just cosmetic issues except the following:
The bike starts when it is cold and seems to run fine. Once it warms up it will not start if I shut it off or stall it out. After it cools again it will start...
Again, even after it is warm is seems to run fine... (yea, ALOT faster then my BMW... WOW!) As long as you don't shut it off or stall... it has to cool before starting again. FYI, The bike has a little over 50,000 miles on it.
Maybe someone out then can suggest where to start looking for this problem...
XFF is offline   Reply With Quote
Old 06-19-2008, 10:03 PM   #2 (permalink)
eddievalleytrailer's Avatar
Last Online: Today 06:57 AM
Sounds like you need to rebuild the starter. You should find the kit at your Honda Dealer.
Proud Member Sixth Gen Militia-1st VTEC Battalion
The Following User Says Thank You to eddievalleytrailer For This Useful Post:
XFF (06-19-2008)
Old 06-19-2008, 10:15 PM   #3 (permalink)
XFF
Thanks for the quick reply!
The starter will crank the bike when it is warm... the bike won't start warm but will stay running if it is warm...
XFF
Old 06-20-2008, 06:32 AM   #4 (permalink)
Yeah. When the starter gets weak, it pulls too much current from the battery, leaving little for the ignition to work with. It will crank over, but won't start. 1st Gen Honda V-4s are famous for this.
XFF (06-20-2008)
Old 06-20-2008, 06:34 AM   #5 (permalink)
CARMINE's Avatar
Last Online: Today 09:14 AM
My Ride: VFR 750 1987
hi, sorry but.....
i do not agree. A starter runs or does not runs at all. I think that you have a problem to the gasoline line (fuel pump and/or carbs). Or it is a problem of overheating (cilinder/rings/gasket). Does the engine tend to boil coolant ? If so, check fan (thermoswitch) : which temp. ?....You can easily install a manual switch to run radiator fan before coolant to become too hot...
Lamps to all VFR Owners.
CARMINE is offline   Reply With Quote
The Following User Says Thank You to CARMINE For This Useful Post:
XFF (06-20-2008)
Old 06-20-2008, 09:12 AM   #6 (permalink)
Moderator
WhiteKnight's Avatar
Last Online: 01-02-2009 11:52 PM
I was thinking valve adjustment on this one. I know on my 3rd gen, if I ran it hard, then stopped for a couple of minutes, when I tried to start the engine I would have to give it a little fuel, as well as for a few minutes after if I cranked on it, it would cut out like it was starved for fuel, but only at about 6000 RPM. After I had the valves checked (way out of adjustment but bike ran great otherwise) and had them adjusted, the problem went away. I might be off base here, but its just my $.02.
http://www.nrwhiteknight.net
The Following User Says Thank You to WhiteKnight For This Useful Post:
XFF (06-20-2008)
Old 06-20-2008, 06:23 PM   #7 (permalink)
XFF
VF1000F not Starting when hot problem...
Hello everyone for are the great ideas!
I'm going to trinker with it this Sunday for a while and if I make any progress I post a reply.
Just discovered a new problem and that is once again when it is all warmed up the clutch slips... I going to did into the service manual for some of this stuff...
Old 06-21-2008, 08:59 AM   #8 (permalink)
JamieDaugherty's Avatar
Last Online: Today 07:11 PM
As noted it's not the starter but rather it's in the carbs. I usually notice this when the carbs need to be rebuilt. I'd give that a shot first, they probably need it anyway.
Problem - Dash Turn Signal Lights Always On (Slightly Dim) VF/VFR Mailing List 0 08-28-2007 07:56 PM
Re: recurring problem Ed Moore VF/VFR Mailing List 5 01-14-2007 08:37 PM
Electrical problem -headlights blown tripswitch & clock resets Cavo Mechanics Garage 0 10-30-2006 10:10 PM
Starter problem 1g gsx Mechanics Garage 0 08-09-2006 08:41 PM
steering problem at higher rate of speed vranak Mechanics Garage 5 06-22-2006 10:11 AM
