Last Online: Yesterday 04:08 PM
My Ride: 1984 Honda VF500F
Coolant and Oil
So as I drive my 84' 500 more and more, I'm noticing more issues. I took her out yesterday in 80 degree weather and every time I hit a red light the temp went almost all the way to the top. The fan was coming on but not until the temp gauge was 3/4 of the way to red. Is this normal? Where should the temp gauge be normally? 1/2 while riding? 3/4 when sitting? Looks like the last owner used only water with no antifreeze. Does water cool better than antifreeze? Should I drain the system and do only distilled water or a mixture?
I'm about to do any oil change since I have no clue when it was done last, but I'm getting mixed information if I should go standard or synthetic. The bike has 43,000 on her so I think synthetic is the way to go. Opinions on that? I did a search and I see a lot of mixed feeling on here as well. |
Last Online: 09-26-2008 02:19 PM
My Ride: 1986 Honda VF500 Interceptor
I just got my VF500 home today. Ive driven it about 60 miles and it seems to run about 1/2 way when driving and at lights it will get up to about 3/4 before the fan kicks on.
Last Online: Today 08:16 PM
My Ride: 1997 VFR750F
Whatever you can afford my friend.
If you only have the nickels for standard oil, that's fine... And no water does not cool any better than anti-freeze. If you don't know the last time the coolant was changed you may want to pick up a gollon of that too! They sell it already mixed 50/50. BZ
"The average man does not get pleasure out of an idea because he thinks it is true; he thinks it is true becasue he gets pleasure out of it". -H.L. Mencken |
#4 (permalink) | |
Last Online: Today 08:41 PM
On oil, just buy a good quality brand name, and change it at regular intervals. If you run synthetic, be sure that it does not have friction modifiers in it (Teflon is one) which will reduce your clutch to a useless pile of plates. Use a wet clutch safe/motorcycle specific oil if you are unsure.
~Jason San Diego Riders click here >>>> San Diego County Area Riders (SCAR) --------------------------------------------------- 1998 VFR800 Two Brothers CarbonFiber Slip-on ZG Double Bubble Oxford Hot grips BMC Air filter Thurn Motorsports Aluminum Chainguard Knurled Aluminum Footpegs Last edited by derstuka; 06-26-2008 at 11:15 AM. |
I guess I stand corrected by Derstuka!
Moderator
Last Online: 01-02-2009 11:52 PM
stuka is a smart cookie. Yes, you can use synth oil if you can afford it. Regular dino oil will work just fine too, just remember to get oil that does not have friction reducing additives cause those are not good for your clutch. You can add water wetter to your cooling system or flush it and put in a 50/50 mix of water and anti-freeze. At one time, you could just by an additive that was mixed in coolant/anti-freeze (glycol?) and add it to your cooling system and help it run cooler. I guess water wetter work on the same principle and I think is more environmentally safe.
