Old 09-23-2008, 01:09 PM   #1 (permalink)
Last Online: 10-07-2008 11:18 AM
My Ride: 1985 VF500F
VF500F - Replacement Rocker Arms
I have two things:
[1] Does anyone have two rocker arms in good shape they would be willing to part with? I have two that are slightly concave and need to be replaced before I button the top end back up. I know it's not good - but how critical is it to have the pad be convex vs. concave?
[2] On a related note - I have tried to put the cams (with sprockets attached) back into their journals - but the chain doesn't have enough slack. I did pull the tensioner arm back and place a cotter pin in the pin hole like the service manual states to loosen the tension. However, it is still too tight and the cams will not fit in their respective places. Any suggestions on how to install them?
Thanks in advance!
hassall is offline   Reply With Quote
Old 09-24-2008, 06:11 PM   #2 (permalink)
Anyone have some information?
Old 09-25-2008, 08:10 AM   #3 (permalink)
loopsandlogic's Avatar
It sounds like you've got everything set up properly.
Pin in place and holding both sides evenly?? It's not just in 1 hole is it?
If so, the tensioner will still have some slack to give.
Second, it may be that your chains have popped off there sprockets right by the cranks down below.
Make sure there perfectly on, or they won't give you the needed slack.
I hope this helps,
LL
"When your driving a Interceptor, there's no rules, there's no traffic, there's just open road and endless possibilities"
loopsandlogic is offline   Reply With Quote
Old 09-25-2008, 11:45 AM   #4 (permalink)
Thanks for the reply!
I do only have the pin in one side. If it's long enough to put through both holes, it's too long to remove once the tensioner is bolted in place. However, I'll see what I can come up with.
Anyone else experience this issue?
New member - VF500F rider dblacknc Introductions 4 06-02-2008 11:55 AM
1983-1985 VF500F replacement windscreen and F2 wheel swap alden First & Second Generation 1983-1989 6 11-04-2007 10:15 AM
Replacement Body Parts Impulse2k1 First & Second Generation 1983-1989 3 07-21-2007 08:29 AM
04 OEM Mirror replacement? rossilvr Sixth Generation 2002-2009 5 12-23-2006 06:09 PM
VF500F sidestand length? J R VF/VFR Mailing List 0 03-21-2006 06:17 AM
