Old 10-06-2008, 10:55 AM   #1 (permalink)
digdoug2's Avatar
Last Online: 11-18-2008 10:06 AM
My Ride: Resurrected 87 VFR700
differences in clutch and brake reservoirs
Am I correct in thinking that I could use almost any year and model front clutch and brake reservoir for my 87 vfr700? The glass is trashed on both reservoirs and I would like to replace with a matching set of something a little newer. I think they would all work the same and they should all be for the same diameter bars....right? I am thinking that the only differences are shape, size and color.
Thanks, Doug
digdoug2 is offline   Reply With Quote
Old 10-06-2008, 11:35 AM   #2 (permalink)
masonv45's Avatar
Last Online: 11-13-2008 02:00 PM
Don't replace the entire M/C.
Just replace the site glass:
Site_glass_replacement - SabMagFAQ
Works for both M/C.
1985 VF700F
Memphis, TN
Old 10-06-2008, 01:32 PM   #3 (permalink)
GenLightening's Avatar
Last Online: 11-19-2008 09:18 AM
My Ride: 1984 VF1000F CDN 2001 Yamaha V Star 1100
There are differences. Bore, stroke, type of lever. Can't really mix and match without knowing what you have, what you need and what you're trying to use.
'84 VF1000F Canadian
100,000+km
CBR1000 front wheel w/ 120-70-17 and 13" rotors
'88 FZR1000 rear wheel w/ 170-60-18
Fox shock and VF1000R reworked forks
Telefix clip-on bars
Megacycle race cams/degreed with HD springs
Supertrapp headers w/8 plates each
De-snorkeled, K&N and full rejet
Oil mod w/ braided stainless lines
All braided hydraulic lines
124 rwhp and 89 ft/lbs tq
GenLightening is offline   Reply With Quote
Old 10-06-2008, 01:43 PM   #4 (permalink)
Banned
Last Online: 10-27-2008 09:50 AM
My Ride: 2007 rwb leo vince slips kn filter only mods
Thanks, Doug
sounds good to me i'd try it if don't work put old back on...
elf800 is offline   Reply With Quote
Old 10-06-2008, 02:34 PM   #5 (permalink)
vfr89's Avatar
Last Online: 11-05-2008 12:34 PM
My Ride: Honda vfr750f rc24II Moto Guzzi Guzzino 65
Thanks, Doug
the original brake pumps are bad...you can change them with every other brake pump on the market...the bars diameter is standard...
If you choose a radial pump you'll have to change the hoses because the plug is in the lower part.
I've bought 2 Brembo 16mm axial pumps coming from Aprilia Tuono.....what a difference
vfr89 is offline   Reply With Quote
Pazzo Brand clutch and brake levers James Bair VF/VFR Mailing List 3 07-12-2007 05:01 PM
Replacing Brake & Clutch Fluid PLCBithead Mechanics Garage 22 05-11-2007 09:26 AM
Vlad the Impalers Brake and clutch Bleed Kit douglasthecook Mechanics Garage 0 04-17-2007 03:23 AM
Clutch and Brake Fluid Change ZonaMan Fifth Generation 1998-2001 1 04-15-2007 10:34 PM
Brake Dancing michael Riding Advice 6 01-13-2006 02:18 PM
