Old 11-12-2008, 06:35 AM   #1 (permalink)
b1pig's Avatar
Last Online: 12-09-2008 08:45 AM
My Ride: 1984 VFR750 Interceptor
Send a message via MSN to b1pig
"new" carbs = holy cow!
i might have mentioned that the carbs on my '84 750 were full of junk. i knew that much since it had been sitting for 3 or more years. well, i located a set of carbs, complete. i got them day before yesterday and tore em down yesterday. only one bad note... one deteriorated diaphram. just one. so, i cleaned em up, removed the jets and cleaned them out. there was some residue, rust and junk in the bowls, but the jets were fairly clean.
i tore my bike down and pulled the carbs. i pulled one slide assembly and the diaphram was good, so i swapped needles, cleaned and installed the slide assembly. Installed the "new" carbs. I never messed with the mixture screws. 3 of the 4 had been drilled out, but I didnt mess with them. I decided not to fool with anything just yet.
after i installed the carbs and put the bike back together, I started spinning it over. i pulled the choke... and there was almost no resistance. i forgot to hook it up.
so, took the tank and airbox BACK off... and hooked it up. spun it over some more... and it fired up beautifully. it didnt want to idle, so i turned the idle screw in a bit. had to later spin it out because it wanted to idle too high. right now, its idling around 1100-1200 rpm. no hesitation off idle. pulls like crazy, and spins hard to 10-grand.
with the original carbs, the engine sounded like it had a knock avery now and then. now, it literally purs with only a slight tick from the valves after warmup. i gotta say that i am impressed. now...... i gotta change the oil out and hope the clutch gets better... since i have no problem telling that its slipping. so far, i have a grand total of $900 in this bike.
b1pig is offline   Reply With Quote
Old 11-12-2008, 08:10 AM   #2 (permalink)
midias's Avatar
Last Online: Today 07:10 PM
My Ride: 1986 VFR750F and 1982 V45 Magna
Send a message via AIM to midias
Nice looks good. Next step is get some new stainless lines for the brakes and clutch and do a full flush and bleed. To me stainless lines were the best mod ever on both my 82 magna and my 86 vfr. I had no idea how bad the others were until I swapped. For the clutch take the slave off and clean the crap out of it and same with the master. Also clean the return hole and use a mighty vac to keep pulling new fluid out until it runs clear. That could help slipping problems although if they are caused by an energy conserving oil rotella T 15w-40 would be a cheap way to replace run for 10 minutes and replace again.
midias is offline   Reply With Quote
Old 11-12-2008, 08:15 AM   #3 (permalink)
derstuka's Avatar
Last Online: Today 08:08 PM
Nice looking like. Sounds like she could use some new friction/drive plates and springs. Good job in gettin' her going.
~Jason
1998 VFR800
ZG Double Bubble
Oxford Hot grips
BMC Air filter
Knurled Aluminum Footpegs
derstuka is online now   Reply With Quote
Old 11-12-2008, 09:28 AM   #4 (permalink)
b1pig's Avatar
i had to replace the clutch master when I got it. the system was completely dry before hand, and i bled it out. took 15 minutes, and i ran a BUNCH of fluid through it... something like 4 or 5 ounces. (i connect an old bottle with a hose for bleeding brakes and stuff)
what did you use for the stainless lines? i havent really looked into it yet, so i dont know if there is a manufacturer that has a specific kit, or if you have to use lines for a different bike.
right now, i have like 3 projects going... this Honda, a '98 Tracker and a '76 MGB that has been on a 4 year holding pattern. :)
Old 11-12-2008, 09:33 AM   #5 (permalink)
Last Online: Today 08:01 PM
My Ride: 2000 VFR 800 fi
YAY, a happy carb story for once.
drewl is online now   Reply With Quote
Old 11-12-2008, 12:25 PM   #6 (permalink)
midias's Avatar
Stainless braided brake lines from a company like galfer are what I am talking about. I have also read Galfer brake lines advertised for vf1000r work for the older vf750f and vf700f. or contact dave dodge he can prob help
http://www.drp123.com/contactus.html
Old 11-16-2008, 06:29 PM   #7 (permalink)
Last Online: 12-03-2008 11:28 AM
My Ride: 1986 Honda VFR700F
Spiegler Stainless Steel Braided Brake Lines
They have kits for the VF's (although not listed for the clutch, but you can order custom lengths as well).
woody77 is offline   Reply With Quote
Old 11-16-2008, 11:21 PM   #8 (permalink)
supertex's Avatar
Last Online: 01-05-2009 08:08 PM
My Ride: '87 VFR 700
Do you have a source for the lines?
supertex is offline   Reply With Quote
Old 11-16-2008, 11:31 PM   #9 (permalink)
Previous post to yours.
1987 Vfr 700F2 - solution to open fuel valve/flooded carbs???? iggy7 Mechanics Garage 3 09-01-2008 05:26 PM
Putting 83 750 interceptor carbs on 85 700 saf First & Second Generation 1983-1989 2 08-07-2008 12:39 PM
Carbs leaking ~1GPM! lammbn First & Second Generation 1983-1989 10 07-25-2008 12:25 PM
Carb maintenance help Olivier Gerouville VF/VFR Mailing List 8 01-04-2008 03:02 PM
WTB: Bank of carbs for 1986 vfr750f guardian86 Buying & Selling 0 11-05-2007 09:43 PM
