Last Online: Today 06:02 PM
My Ride: '84 VF500F, F4i Conv.
VF500F Dimension Double Check
Hi All,
I'm looking for a double check on a couple of VF500F dimensions. I've attached a drawing for reference. The dimensions are:
Many thanks! |
Last Online: 11-15-2009 11:22 PM
My Ride: current ride:86 VFR 700 F, by way of Kawasaki 500, Triumph TR6, Guillera, Honda Trail 90
nice drawing
Do you have access to to a CAD program? You should try to get JamieDaugherty to give you dimensions or maybe Matt1986vf500f who has modified his rear wheel.
Vf500F Dimension Double Check
#4 (permalink) | |
Last Online: Today 10:04 AM
My Ride: 84 VF500F
hope that helps |
mm
Last Online: Today 12:06 PM
My Ride: 2008 Ducati 1098 - 1998 VTR1000F -
3x 1984 VF500F - 1984 VF1000F - 1985 VF1000R - 1984 VF700F
Let me know if you still this info. My 500's don't have the stock wheels anymore but I can double check with my CAD models for you.
drawings
My models agree, more or less. For the sprocket side dimension I have 17.5mm. That's from the outside of the sprocket (530 size) to the inside of the chain adjuster. Note that this not to the inside of the swingarm leg itself. A 530 sprocket is approximaltely 9.5mm thick (30/80ths, or 0.375in) so the actual controlling dimension is 27mm to the sprocket mounting face. I hope this helps! |
| The Following User Says Thank You to JamieDaugherty For This Useful Post: | invisible cities (11-05-2009) |
#9 (permalink) | |
#10 (permalink) | |
No, sorry. I didn't detail that area out in my models because I was never going to use the stock rotor or caliper bracket. |
#12 (permalink) | |
#13 (permalink) | |
The chain adjusters are 3mm thick material so the dimension you are referring to would be 30mm. |
| The Following User Says Thank You to JamieDaugherty For This Useful Post: | invisible cities (11-09-2009) |
#14 (permalink) |
cush drive and sprocket
Hi All,
Would someone out there have a spare stock VF500F cush drive and sprocket handy? I could use a dimension double check (4 dim's to be exact) - please see the enclosed drawing. Many thanks! Last edited by invisible cities; 11-12-2009 at 08:36 AM. |
A couple of comments:
1) The sprocket depends on the series. Assuming it's a 530 chain, that means it's 30/80in or 0.375in thick. That would be 9.52mm. 2) Two of the dimensions you are looking for go to surfaces that are not functonal. There are two very key dimensions that you do not show. One is from the sprocket mounting surface to the bearing inside edge. The other is from the sprocket mounting surface to the clearance for the wheel hub. I'll see if I can double check those for you tonight. |
| The Following User Says Thank You to JamieDaugherty For This Useful Post: | invisible cities (11-12-2009) |
#16 (permalink) |
Apologies if I'm being daft but for the VF500F's stock 530 chain (.375" roller width) wouldn't the sprocket thickness be .343" (8.72mm)? Thx!
#17 (permalink) | |
You are not going DAFT!
DKC |
#18 (permalink) |
That's interesting, all of the sprockets I've measured have been pretty close to the nominal size. Now you guys are going to make me go measure some sprockets.
The idea here is that you should not take any measurements from the outside of the sprocket. The controlling surface is where the sprocket mounts to the carrier. |
#19 (permalink) | |
sprocket and hub
Would you happen to have a spare VF500F hub on the work bench for a double check of the other dimensions? |
#20 (permalink) | |
sprocket and hub
| VF500F Dimension Double Check | invisible cities | First & Second Generation 1983-1989 | 0 | 11-02-2009 02:28 PM |
| Results of Valve Check on V-tech..... | bostonexchange | Sixth Generation 2002-2009 | 16 | 10-09-2009 07:39 PM |
| VF500F with multiple problems | liquid | First & Second Generation 1983-1989 | 12 | 07-25-2009 02:44 PM |
| VFR 750FV Shim Check with Pictures. | Sye | Maintenance | 6 | 03-13-2009 02:14 AM |
| Valve clearance check | Gurra | Mechanics Garage | 2 | 04-13-2006 12:56 AM |
