Old 03-22-2007, 04:47 PM   #1 (permalink)
puckstr's Avatar
Last Online: 08-02-2007 03:16 PM
My Ride: 86 VFR700F
clutch slipping. slave cylinder not retracting
Ok here is it 86 VFR700F 8800 miles. Clutch seems to be slipping.
I install a new clutch. Test drive and the clutch is still slipping.
Inspect the slave cylinder and the plunger is extending too far.
Crack the bleed valve, push the plunger in. Test drive solid clutch hook up
doing wheelies.. but 30 miles later the clutch is slipping again
limp home look at the slave cylinder and the plunger is out too far again.
What the heck.
thanks
puckstr is offline   Reply With Quote
Old 03-22-2007, 05:20 PM   #2 (permalink)
fiddlercrabus's Avatar
Last Online: 03-25-2007 11:58 AM
My Ride: 1984 VF500F Streetfighter 1986 VF500F Stocker
I would also be interested in any info anyone can provide. I have an '86 500 that the cluth hydraulics don't seem to do anything at all. I have bled the line, but the clutch is just a dead lever.
"Cundelini wants his hand back."
fiddlercrabus is offline   Reply With Quote
Old 03-22-2007, 10:21 PM   #3 (permalink)
Squidleyous Maximus
reg71's Avatar
Last Online: Today 03:20 PM
On my 500, I had to rebuild the slave cyclinder. Someone gave me a link to a slave cylinder rebuild kit on ebay for a good price. It was an easy fix and then bled the clutch and voila, I had a working clutch...I had never done it before, but it was not bad at all.
Reg71 - Central Coast, CA
98 VFR 800 - 5G Brotherhood
Old 03-23-2007, 06:07 AM   #4 (permalink)
Last Online: 03-07-2008 03:05 AM
In the master cylinder there are two holes 1 feed and 1 return, if the return hole gets partially blocked it can cause the symptoms you describe as the cylinder stays partially pressurised
vifferj is offline   Reply With Quote
Old 03-23-2007, 11:25 AM   #5 (permalink)
puckstr's Avatar
My Ride: 86 VFR700F
thanks brother
I will take a look at it today. Hopefully I will be riding tonight
Ok I took both the Master and Slave apart. wow loads of orange gue!
the master has 2 holes in the resevoir one was completely plugged up.
cleaned the passage (drill bit).
Flushed the works with fresh DOT4. Seems to be all good now test drive SOON
See you on the road SKAGG!!!
Old 03-27-2007, 07:42 AM   #6 (permalink)
Last Online: 04-13-2008 01:05 PM
Just an FYI, overfilling the reservoir can cause the same symptoms on both the brake and clutch systems.
samiam is offline   Reply With Quote
Rebuilding Slave Cylinder Fixed My Clutch rjhartmann Mechanics Garage 1 04-07-2008 06:08 AM
Clutch slave cylinder fell apart (?) VT Viffer Mechanics Garage 5 03-31-2008 11:14 AM
Clutch adjustment? chris in va General VFR Discussions 5 07-21-2007 05:56 AM
Squishy Clutch Lever due to Slave Cylinder ChrisPaegelow Mechanics Garage 1 05-08-2007 11:23 AM
clutch slave cylinder ride1 Mechanics Garage 3 10-08-2006 02:05 PM
