Old 06-24-2007, 01:16 PM   #1 (permalink)
pontiacformula99's Avatar
Last Online: 10-14-2008 12:10 PM
My Ride: '87 VFR 700F2
Replacing Slip ons?
I've been looking at replacing my old scuffed up kerker slip ons w/some new or used Two Brothers C/F cans. Are most slip on's interchangable other than the inlet pipe size? I have access to a welder and could put a adapter on the pipe to fit the inlet but I'm worried about the possibility of back pressure issues or jetting problems. I've found a set off a 99 Blackbird 1000 and they look like they'll mount in the right location but I'll have to adapt the inlet to fit. Will these cause engine problems or should I stick w/cans designed for 600-800 motors? This is going on a 86 700F.
Thanks Guys
James
pontiacformula99 is offline   Reply With Quote
Old 06-24-2007, 02:01 PM   #2 (permalink)
speed's Avatar
Last Online: Today 01:41 AM
James, I have a 1986 VFR750F , and i have C/F cans from a Ducati 900ss, you just have to fit and weld the inlets like you stated, my engine also is a 840 c.c. built by dynamo humm back when they still built engines, if i could figurer out how to post pictures on here i would do it ?
take care and good luck
Old 06-24-2007, 06:38 PM   #3 (permalink)
JamieDaugherty's Avatar
Last Online: Today 10:20 AM
The pipes that I've found to be the easiest to install are ones from a VTR1000F SuperHawk. They require a little tweaking but actually fit pretty easily.
Old 06-24-2007, 07:00 PM   #4 (permalink)
Outlawz24's Avatar
Last Online: 11-25-2008 04:37 AM
My Ride: 1985 Honda VF750F Interceptor,1977 Honda CB550K, 1973 Kawasaki S2
Send a message via AIM to Outlawz24 Send a message via MSN to Outlawz24 Send a message via Yahoo to Outlawz24
Which models will the VTR pipes fit on? Also what needs to be done to adapt them? I would like to hear more about this...i thought i had read something about VTR pipes fitting on the VF as well or at least the 1st/2nd gen bikes on here.
The stupidity of one causes the agony of many....
77 Honda CB550K
72 Kawasaki S2 350
Outlawz24 is offline   Reply With Quote
Old 06-24-2007, 07:31 PM   #5 (permalink)
I have access to a plasma cutter, mill, welder, 20 ton brake press, surface grinder, and an endless supply of flat plate... I'm not worried so much about the placement or fabrication of mounts, but the effects on the motor. I've heard that messing around with the back pressure can really screw up the engine. Is the back pressure even an issue with slip ons or should any of them work about the same?
Old 06-24-2007, 07:31 PM   #6 (permalink)
speed's Avatar
Hey JamieDaugherty,
what type of bike do you ride ? and where ? i would love to get on a track soon , tim (speed)
Old 06-29-2007, 06:11 PM   #7 (permalink)
Outlawz24's Avatar
I ride with a VTR owner and yesterday i took a quick look between the bikes to figure out what would need to be done to install VTR cans onto a VF...its actually quite simple...a new straight section of pipe to go between the cans and the crossover needs to me made along with moving the clamp in line with the mount holes on the rearsets. one could move the can in a fair bit closer to the front pegs if they wanted to live with out the center stand. Personally i think im keeping the stand as it comes in handy for maintence. gonna look a little more into it as i might just opt to mount the cans in about the same place as the pass pegs. Will let everyone know how my progress goes once i can afford to buy some VTR cans..
77 Honda CB550K
72 Kawasaki S2 350
Old 06-29-2007, 08:39 PM   #8 (permalink)
You don't even need to go to that much trouble. Just get a set of VTR pipes and attach them to the VF's collector. You need to tweak the angle a little, but sometimes you have to do that when installing them to the bike they ARE supposed to be for. Aftermarket pipes are easiest because the mounts can (usually) slide along the muffler until you line up with the rear mounts.
Backpressure changes won't "really screw up an engine" but can cause power issues. Too much or too little can cause peaks and dips in the power curve. Slip-ons do not produce very much on the V4's, in fact they can often result in a decrease in power. We are talking maybe 3hp here, so it's not huge. If it's looks and sound that you are after, anything will fit the bill.
Old 06-29-2007, 08:43 PM   #9 (permalink)
Outlawz24's Avatar
The VTR i was comparing against had D&D pipes on it. and im assuming the pipes going from the collector to the cans arent welded in place just clamped in right? Would make said tweaking easier lol. hmmm using said pipes would probably give me the clearance i need...bonus!..
77 Honda CB550K
72 Kawasaki S2 350
RE: Replacing the tail light with an LED setup - ideas? Matthew Roth VF/VFR Mailing List 0 04-16-2008 12:34 PM
Third Generation Slip ON - HELP pontiac_banshee Third & Fourth Generation 1990-1997 24 10-23-2007 05:46 PM
Slip on Exhaust jrvfr93 Modifications 2 03-26-2007 12:59 PM
Slip on Exhaust jrvfr93 General VFR Discussions 2 10-20-2006 07:44 PM
Gasket between collector box outlet and stock slip on vic5491 VF/VFR Mailing List 6 02-03-2006 02:46 PM
