Last Online: 11-11-2008 02:05 PM
My Ride: 2000 VFR800
Cateye bicycle computer...on VFR
Hi ladies and gents,
I have been thinking for a while about purchasing a bicycle computer to put on my VFR, so I can calibrate and know my true speed. I thought I would post my results just in case anyone else wanted to know. On Saturday, I purchased the Cateye Velo 5 bicycle computer from a local bike shop for $19.99. This is Cateye's simplest model, and includes odometer, trip odometer, speed, max speed, and clock. The odometer is only capable of reading 9999.9 miles, but I didn't care about that. The speedometer, however, is capable of reading up to 180 mph, and of course, displaying your top speed. The unit comes with a round magnet, which is just slightly smaller than the holes in the rivets for the semi-floating rotors. You could probably mount it in there with a small amount of JB weld. I had a magnet that fit perfectly in the rivet, so I pushed it in after applying a small amount of Bondini gel (super glue). The pickup unit mounts to the fork with zip ties, and needs to be within 5mm of the magnet, which is easily achievable. After installing the display mounting bracket on the upper triple clamp with double sided tape, I calibrated the unit to the measured circumference of my front tire; 187cm. My front tire is a stock size 120/70-17 Dunlop D220, and should be very similar to any other 120/70-17. Next, I rode along a quiet road with mile markers to determine the accuracy of the odomoeter calibration. It was within .05 miles. Yes, that's 5/100 of a mile. I'm calling that close enough. I know for sure it will read up to 120 mph, since I achieved that speed on the way home yesterday. That was only to test the unit, of course... ![]() It's a very simple unit to install and setup, and for $20 I know my true speed. This is nice if you have different size sprockets, tires, anything else that may throw off your speedometer, including the factory setup. I still don't understand why the manufacturers build in speedometer error. This is also nice if you have made modifications of the sort and would like to know the true mileage from origination to destination. |
Last Online: Today 12:34 PM
My Ride: 2005 VFR 800 ABS RED
Ha, I love it. Not a bad idea i'm sure everyone has instaled one on the bike bike at some point, not sure why i never thought to use it on the cycle...hmmm
Proud Member-Sixth Gen Millitia-1ST VTEC Battalion |
Last Online: Yesterday 01:45 PM
My Ride: 1999 VFR800fi
These are great if your bike (not the VFR) does not have a tripometer. Some models have a backlight that enables night time reading. Most are waterproof. Is the Velo a wired or wireless model. Thanks.
Wired
The Velo 5 is a wired model. This was my preference for a couple of reasons. One, it was cheaper than the wireless models, and two, the batteries will last longer in the wired model.
Last Online: 08-29-2008 06:25 PM
If you are going wired, get a mountain bike specific model with the heavy wire. Like the Cateye Enduro.
Also , for the most accurate readings, mark your tire and measure the distance it travels in one revolution. There is a chart in the instructions down to the mm. |
Last Online: 10-11-2008 07:28 AM
My Ride: 1993 Honda VFR750f
The bicycle speedo will not be any more accurate. Once you climb above 40mph your tire expands and the diameter changes slightly. The only way to get a TRUE reading of speed is to use a GPS. Calculates speed by relative position on the earth surface, not by revolutions of your wheel.
Last Online: Today 03:14 PM
My Ride: '96 Honda VFR 750,
'90 Honda Hawk GT
I think the bicycle speedo is still more accurate than the stock speedo. I've used a gps and found the stock speedo to be 8-10% fast.
'96 VFR: Totally Stock 14,xxx miles '90 Hawk GT: Modded 40,xxx miles Ducati: Making mechanics out of riders since 1946 |
Last Online: 11-10-2008 07:02 AM
My Ride: 2007 VFR800 RWB
I carry my Garmin Edge 305 (cycling computer) that I used on my Orbea road bike. GPS based. You can download everything to your laptop including your map, etc...
The Garmin Edge 605 is my next toy. The map on it is awesome. Looks like the Nav display in the car Raisin is right though. Pretty interesting to see your average, max, etc... Now, gotta find a way to read endurance, average fuel burn...
PROUD MEMBER 6TH GEN MILITIA 1ST VTEC BATALLION |
| Re: vfr Digest, Vol 52, Issue 13 | Steve | VF/VFR Mailing List | 0 | 07-18-2008 04:17 PM |
| Re: "97 R/R | lmitch5085 | VF/VFR Mailing List | 0 | 05-27-2008 07:31 PM |
| Blackbird to a VFR – a daily, performance riding and touring perspective | two4one | General VFR Discussions | 23 | 05-17-2008 04:10 PM |
| RE: vfr Digest, Vol 43, Issue 8 | Andrew Bertsch | VF/VFR Mailing List | 1 | 10-04-2007 05:05 PM |
| 95 VFR fork size | Ed Ostack | VF/VFR Mailing List | 3 | 09-18-2006 06:45 PM |
