Last Online: Yesterday 07:07 PM
My Ride: 1996 VFR750
A little electrical help
Have not dived too far into this one yet, however seem to be running into some type of electrical issue on my 4th gen.
This has happened twice now. First time about 2 months ago, after a 2 hour ride, had a quick 15 minute rest, get back on the bike turn the key, get all relevant lights, however bike does not start turning over when starter is pressed. Turn off key, turn on key again, this time, no dash lights, no nothing. Start pondering what my next move is going to be. I notice that the clock reads 1:00 as if it had just at the second I turned it over the first time, it reset....thus battery got disconnected. Wait a couple of minutes, turn key again, this time getting all dash lights, and bike starts. I thought it was just a fluke. Fast forward to today. Rode for about 3 hours, went into the post office for about 30 mintues, come back out to the bike and got the correct time off the dash clock, turn key........nothing. No dash lights, no nothing. Clock is reset back to 1:00 again. Turn key off, turn key back on...nothing. Waited about 5 minutes, turn key back on again, nothing. No dash lights or anything. Thinking I am in a little more trouble this time and thinking I could have a lose battery connection, I remove the seat, wiggle the battery cables a little, give them the secret genie rub, and what do you know. Turn key....dash lights are on, bike starts right up. Note to self, the battery cables seemed to have a pretty snug connection. I have had the battery tested, and even though it is a 4 year old battery, it tests perfect and provides adequate juice. Any ideas peeps?
http://www.youtube.com/watch?v=UuhfMFLxVwA |
200ccs Up
Last Online: 01-04-2009 06:49 PM
My Ride: '85 Honda VF500F
'90 Yamaha Radian
'07 Yamaha FZ1
Sounds weird. I'd get some aerosol electronics cleaner and blast away at all the connections you can find. Spray down the terminals with the stuff but be sure to apply some dielectric grease. I'd also pull all your fuses, spray and take them in/out repeatedly to clean the contacts.
No idea otherwise though.
Lame joke of the week: Why do Motorcycles want to fall at stops? Because they're two tired! |
Last Online: Today 04:35 PM
My Ride: '06 Interceptor
My friends '97 did that this summer. He had two issues at the same time, one was a corroded kill switch that made it seem as if the battery was disconnected. So follow up on what Fizz suggested. Also, the second problem was his R&R was shot. After some contact cleaner, and an aftermarket R&R, all is well.
Mac |
Last Online: Today 08:16 PM
My Ride: 1997 VFR750F
clean your battery connections with a scotchbrite pad too. Can be some corrosion underneath thats causing an issue too.
BZ
"The average man does not get pleasure out of an idea because he thinks it is true; he thinks it is true becasue he gets pleasure out of it". -H.L. Mencken |
Last Online: Today 02:03 PM
My Ride: 2003 VFR
Spoken from experience? Hmm, Hmmm????
2003 VFR, 2002 SV650 |
You could say that
![]() Missed a track day as you know because of it ![]() BZ p.s. Did you or PA watch any of us slow B-broup guys/ gals on Nov 1st?
#7 (permalink) | |
Last Online: 12-01-2008 12:13 PM
My Ride: 6th gen
4th Gen Guru
Last Online: Yesterday 03:02 PM
My Ride: 1994 VFR
Hmm, had this problem occasionally, but not since I replaced the R/R
Capo - 4G Mafia 1994 VFR - H4 Silverstars, 2 Bros. SS/CF exhaust, re-snorkled, chopped rear fender, amber rear running lights, Metzeler SporTec M1s, forks raised 10mm, 929 shock mod, Zero G Double Bubble. |
#9 (permalink) | |
Last Online: Today 05:36 PM
My Ride: '85 VF700f
'78 CB750f
'75 CB400f
Start with the battery and good luck. |
Thanks for all the ideas. Still have not had a chance to work on this, however the problem has become drastically worse.
When riding the bike now, it will start to run extremely rough, as if I have some bad gas in there, or as if I am running out of gas. Bike seems to want to cut out. I noticed when this was happening, the speedo and rpm guage, would drop to 0, then come back to life as the dash lights flicker in time with the engine spurting. So yes, absolutely something to do with battery not supplying power. I was stranded for about 30 minutes, and didnt have my relevant key to take the cowl off, to take the seat off and wiggle the battery, so I just hit on the seat, right near the battery, and bingo!....got all dash lights and bike would start again. Had to stop again, could not get bike started, even by hitting seat, so now, to get power, I would straddle the bike and with aggression rock the bike side to side, and eventually dash lights would light up. Eventually I got home. But yes, has to be something around the battery terminals. Will update when I get a chance to work on it.
#11 (permalink) | |
My Ride: 6th gen
#12 (permalink) | |
Moderator
Last Online: 01-02-2009 11:52 PM
Note: Slick50 is not needed for this procedure and is not recommended for repair of this problem. |
#13 (permalink) | |
Last Online: 01-05-2009 05:15 PM
Hershey's Syrup. Making chocolate pudding out of vanilla pudding since, about 5 minutes ago. |
#14 (permalink) | |
Exact simptons of my Buddy's '97! A good beating and some cussin', and it would run. R&R, and a bad connection. Mac |
Last Online: Today 08:10 PM
My Ride: 1997 Honda VFR
Same problem I had until...
... I went ahead and rewired the middle of the bike (or so it seemed).
Long story short: bought a '97 this May with 3800 miles on it. Didn't have it a week and it stranded it me twice. SO-replace R/R with a GSXR one, eliminated as many connectors as I could. Ran a ground direct from the R/R to the frame, ran a power lead direct to battery w/ 20 amp fuse, and some other stuff (there is plenty on this fix already on this site-it works). NO problems in 2000 miles. Oh, the computer fan on the R/R is a must here in Albuquerque (summer commuting temp on way home can be +105F) It's a pain to be working on it when you should be riding it BUT it's worth it to have a reliable ride. |
#16 (permalink) | |
200ccs Up
'90 Yamaha Radian
'07 Yamaha FZ1
EDIT: http://www.amazon.com/CRC-5102-QD-El.../dp/B000BXOGNI "Quick drying, plastic safe formula leaves no residue"
#17 (permalink) | |
Last Online: Today 08:54 PM
I have never had a problem like this either, maybe it is brand specific? If so, please name the exact product you used, so the rest of us can hopefully avoid any problems.
