Results 1 to 4 of 4
Thread: gutting exhaust
    Member northernrider's Avatar
    Mar 2009
    north bay ontario
    2002 vfr
    54
    gutting exhaust
    hey all just wanted to post that i gutted my exhaust and chose to remove all the pipes and internals .
    and with this said my 2 cents is , if u can chose the non weld method ! shit i had a hard time getting the center bracket out that holds the pipes . the bottom was easy cause the welds were right on top but the first one i tried using a chisel and was just not fun , on the second one i cut the glass pack and drilled the rivets , a little bit easyer but when i re- wrap the the glass pack and shoved it down the pipe about a quarter of it slipped up and had to cut the exsess off . anyway i havent hered it yet cause the pipes are off to the welder for re-welding , so i hope the sound is worth the damm trouble lol . anyway knowing what i know now if i was to chose i would chose the easyer way of using a cutter wheel it cut the inside of the pipe ( the non- weld method ) .
    now i know there will others out here saying it was a brezze but just wanted to post my 2 cents for the not so mechanicaly inclined ou there !
    Member DashCrasher's Avatar
    Oct 2007
    Southwestern Ontario
    2000 VFR800fi
    42
    What exhaust did you have? On my 2000 vfr I gutted my stock exhaust and had no rivets or glass wrap. There's only 2 baffles in the stock can as well.
    DashCrasher
    _____________________________________________
    5-G Brotherhood
    Mar 2009
    north bay ontario
    2002 vfr
    54
    stock exhaust on a 2002 . i hope it sounds better gutting the whole thing instead of just cutting out the 4 pipes with a die cutter cause i went though alot of bs ..lol
    Aug 2008
    Petawawa, Ont
    1986 VFR 750 RWB
    56
    I gutted my 86 pipes but only removed the silencers and it sounds awesome now. Going to pick up my new scorpions tomorrow so i look forward to putting those on. I couldnt find any info on gutting the 86 model so I just used a sawzaw and cut the ends off both pipes. Pulled out the silencers and had a buddy weld them back on. A touch of black paint and I now have black tipped exhaust that sounds nice.
  1. gutting headers
    By oh whell in forum 6th Generation 2002-2009
    Last Post: 12-18-2009, 11:43 AM
  2. Gutting 87 exhaust
    By zPix87 in forum 1st & 2nd Generation 1983-1989
    Last Post: 03-25-2009, 08:33 PM
  3. compared to gutting...
    By ares in forum 6th Generation 2002-2009
    Last Post: 03-05-2009, 02:18 AM
  4. gutting stock exhaust
    By tremaineiz in forum 6th Generation 2002-2009
    Last Post: 08-17-2008, 11:08 PM
  5. Benefits of Gutting Cat???
    By jb5371 in forum General VFR Discussions
    Last Post: 03-12-2007, 07:14 AM
