Last Online: Today 09:35 AM
Real wheel sliping
My new continential rear wheel has been slipping today. I pulled out a little fast today and then it started slipping out from under me. Did it another time as well. and seemed to slip too much when someone pulled out in front of me.
Last Online: Today 09:06 AM
My Ride: 2000 VFR 800 fi
How new is the tire?
Brand new? They have a coating on them that needs to be scrubbed off before riding. Not brand new? You may have some throttle control issues that need to be worked out. A smooth throttle is a happy throttle.
Shop Steward:Chat Hooers Union, Local 151 Ministry of Activity and Participation |
| The Following User Says Thank You to drewl For This Useful Post: | RedRover5683 (11-03-2009) |
well. im not going to say I was excited not having the trailer off.
and not brand new. im thinking that it might simply have been road conditions. westnedge seemed a little slippery today. |
Last Online: Yesterday 12:06 PM
My Ride: 2008 Ducati 1098 - 1998 VTR1000F -
3x 1984 VF500F - 1984 VF1000F - 1985 VF1000R - 1984 VF700F
Low tire pressure? That's the most likely culprit for acting like that. The VFR's don't have that kind of power, no matter how ham-fisted you are with the throttle.
Road conditions are a killer. Remember that ice patch? Be careful out there.
Last Online: Today 10:47 AM
My Ride: 2004 VFR Asphalt Black
Remember that cold weather is setting in. Tires take longer to warm up and the road is quite a bit colder. I've already slid the tire twice this month, something I haven't done at all since I have owned my VFR. Both times it was cold out and I had less than 3 miles in. Check your pressures and ease up a bit so your tires can warm up.
Iv got plenty of miles on them. Honestly i think it was just road conditions. it seemed quite slipery.
Ill definatly be checking the pressure tho. |
Last Online: Yesterday 06:43 PM
My Ride: 1997 VFR750F
Go, what happened to the tires I sent you?
BZ
"The average man does not get pleasure out of an idea because he thinks it is true; he thinks it is true because he gets pleasure out of it". -H.L. Mencken |
i had already purchased the rear tire just before. i have the front tire you sent on it now.
Last Online: Yesterday 03:03 PM
My Ride: 02 RC 46
too much air maybe
if it is cold you dont want to be running 42 psi in the rear
ZG dbl bbl, semi gutted stock exhust " The Chip " power mod, 19mm tail riser and cool red grips ![]() ![]() ![]() ![]() ![]()
Eye Poker
Last Online: Today 09:15 AM
I was going to say too much pressure. shoot for mid to low 30s for a faster warmup
2006 Ducati 999S Nero Mono Limited Edition 1992 Honda VFR750F (reborn) 2004 Ducati 998S Final Edition 2002 Royal Enfield Bullet 1992 Honda VFR750F 1993 Suzuki GSX-R 750W 1990 Honda CBR600F 1989 Honda CBR600F 1973 Schwinn Stingray 3 Speed
it only did it on that one road. im pretty sure it was just slippery.
so bow does different air pressures effect riding and what pressure should i use at different times of the season |
Eye Poker
in general tire pressure is a very high determinant of ride quality, tire wear and handling. A lot of handling issues arise from too much pressure, and wear issues from too little.
Ideally you want the tire, when hot to be in the middle of it's range, on modern tires this is 34-36psi. On the track we generally run 27-28lbs cold which allows the tire to both heat up fast, not overheat and have some sidewall flex to absorb track imperfections as well as to keep the meat of the tire in contact with the track surface. This of course is at the expense of wear. Track wear is 5x-7x per mile as what you see on the street (same applies to oil and brake pads). Too much pressure will help tire wear and life, but causes the tire to overheat quickly and get greasy during more aggressive maneuvers. Easiest way to check is to test your pressure cold, ride your normal ride and test pressure upon reaching a stopping point. Ideally the pressures should not vary by more than 10-15%. If pressure is more than that, you are running too high a pressure.
#14 (permalink) | |
Last Online: 11-04-2009 08:05 AM
My Ride: 86 VFR-75 H1-79 FX- 03 Busa- 05 Concours
XR's 100 250 400
Last Online: Today 11:54 AM
My Ride: 2007 VFR800A
If your Continental is a Road Attack, they are notorious for taking quite a bit longer to warm up compared to other tires. I recently put them on my 07, and since then have allowed longer warm up time before asking them to work hard. Seems to work for me.
Know the rules, so you can break them properly. Slow is smooth. Smooth is fast. Proud Member 6th Gen Militia, First VTEC Battalion www.southwestrides.com |
#16 (permalink) |
contiforce
| Wheel conversions for 1986-1987 | adam48060 | First & Second Generation 1983-1989 | 47 | 10-02-2009 05:16 AM |
| Can you put a 6th gen. real wheel on a 5th gen. bike? | casualfornow2 | Mechanics Garage | 3 | 07-21-2009 08:35 AM |
| HP ratings from a dyno ? | JWB-VFR | General VFR Discussions | 10 | 06-17-2009 07:26 PM |
| rear wheel swap | PingKing | Brake & Tire Articles | 3 | 10-05-2008 06:29 PM |
| Who knows of a good lift stand for the real wheel? | AWESOMEVFR750 | Mechanics Garage | 4 | 10-17-2003 09:40 AM |
