Old 08-06-2006, 07:43 PM   #1 (permalink)
keet's Avatar
Last Online: Yesterday 06:19 PM
My Ride: 98 VFR
i got a prob
hi folks....i recently got a 98 vfr...used to have a goldwing and also a fj1100...the prob is that my throttle hand goes numb quickly after a relatively short time in the saddle....it gets pretty annoying,and i have to slap my hand on my thigh to keep normal feeling...the left hand is fine....what gives?...should i investigate getting gel handgrips?....other than that i really LOVE the bike....thanks!!
keet is offline   Reply With Quote
Old 08-06-2006, 08:10 PM   #2 (permalink)
Last Online: 04-18-2007 01:11 PM
My Ride: 1998 vfr 800
numb hands
I have a '98 as well. I have genmar bar risers and gel grips, and rarely do my hands go numb. They seem to be making a difference even on 500+ mile days. Other things I do to avoid going numb are: be careful not to put to much weight of my upper body on the bers, lean on the tank bag on long hauls, and position your body further back or forward on the seat depending on what feels right. A good pair of gloves make all the difference as well. Heli bars are another brand of bar risers that mount to the fork tubes. They are the actual bars as well, where as the Genmar risers are spacers that fit beneath the stock bars. I think the advantage of the Heli's are that you have more adjustability of the lever and controls, but cost more and may require lengthening the brake and clutch lines. The Genmar are cheaper, easier to install, but don't raise the bars as high as the Heli's. Good luck!
rottriley1 is offline   Reply With Quote
Old 08-06-2006, 08:26 PM   #3 (permalink)
jethro911's Avatar
Last Online: 08-10-2008 06:24 PM
My Ride: 1990 vfr750 sold 1998 vfr800 sold 2001 Ducati 748 1998 VFR 800 again! 2001 Ducati 748 "tracktime"
I found a big difference when I changed my steering head bearings from stock (balls) to tapered rollers. I guess it changed the way the vibrations were transmitted from the engine, through the frame and into the steering head.
The kit was from All balls Racing.
Gel grips were the answer for my older 91 VFR.
Jethro911_Belleville Ontario_1998 VFR800
" You can teach a monkey to ride a bike but what is he gonna do when the chain falls off"
jethro911 is offline   Reply With Quote
Old 08-06-2006, 10:46 PM   #4 (permalink)
elizilla's Avatar
Last Online: 11-26-2007 05:10 PM
My Ride: 1994 Honda VFR, 2003 Suzuki DL1000, 1992 Yamaha TDM850
Have you tried doing a throttle body synch? It might reduce vibration.
elizilla is offline   Reply With Quote
starter prob possum2082 Mechanics Garage 0 09-13-2007 08:52 PM
only 7k now thats a prob... BuLLeT TootH First & Second Generation 1983-1989 1 08-14-2007 08:02 AM
