Last Online: 11-20-2008 02:25 PM
My Ride: 1983 VF750F
1986 Concours
83 VF750F valve adjustment question
hello, i'm new to the vfr community. i have rebuilt a 83 vf750f which i bought all taken apart. sorry no pic's yet. my question is in regard to valve adjustment. i have started out at tdc at the indicated t1-3 and adujusted the clearances on cyl. #1 (left rear). next rotating ccw 90 degrees to t2-4 to adjust cyl. #4 (right front) the rocker arms are not loose and the cam lobe is in a position where i can't get a wrench on to loosen the locknut. now the odd part, the rocker arms for cyl. #2 (left front) are loose and those valves look ready to be adjusted. after rotating ccw 270 degrees again to t1-3 cyl. #3 (left rear) could be adjusted. then rotating ccw 90 degrees again to t2-4 cyl. #4 is know ready for adjustment. it seems to me that cyl #2 and #4 cams are somehow reversed or am i missing something. i am not new to motorcycling i have been riding 20+ years and have done this kind of work all along. any help would i can get would be great.
1986 Concours
problem fixed
the vavle problem has been fixed. someone must have worked on the motor before i got it and when replacing the cams did not index them properly.
Last Online: Today 09:06 PM
Hello and welcome to the forum. Glad you got the valve issue worked out.
Make sure you either use the Honda cam tool or put a feeler gauge under each screw for the side you are adjusting. Otherwise, the cam can rock in it's mounts and give you a false reading...
1986 Concours
thanks for the info. i have a honda shop manual for this bike. i just need to get another feeler gauge so that i have two of the correct size.
| Valve Adjustment - Chicago Area | daeven | VF/VFR Mailing List | 1 | 12-31-2007 10:57 PM |
| Valve Adjustment Question | kinome79 | Third & Fourth Generation 1990-1997 | 12 | 12-18-2007 11:23 AM |
| parts for a valve adjustment | digger | First & Second Generation 1983-1989 | 3 | 06-05-2007 07:34 PM |
| valve adjustment parts | digger | VF/VFR Mailing List | 2 | 03-26-2007 08:58 AM |
| Valve adjustment on a'93 VFR750 | Olivier | VF/VFR Mailing List | 1 | 04-03-2006 04:19 PM |
