Results 1 to 4 of 4
Thread: Gear Swap Question
    Jun 2007
    Gear Swap Question
    I have a 91 and it's time for a new chain and sprockets. I do a lot of long distance riding in top gear at about 85-90 mph and was wondering if it would be a good idea to run taller gearing for lower rpm and better gas mileage. Any suggestions?
    Senior Member dale-j's Avatar
    Mar 2007
    British Columbia, Canada
    1989 FJ1200 (sold) 1993 VFR750
    177
    I did this on my old FJ1200, but found that it made it harder on the clutch getting the bike out of the hole in first (granted, that bike only had a 5 speed) and also made slow speed riding in traffic a chore. It didn't really make that much difference on top (500 rpm IIRC), and I made a pretty dramatic change from 17/41 to 18/38. If you do change it, I'd recommend keeping it to maybe plus one on the front and only one or two down in the back. The advantage of adding one on the front is that it makes your chain bend less around the small sprocket, so less heat and less wear.
    Steve
    Delta, BC
    1981 XL80S (first bike, bought new in '81)
    1990 GSXR750 (sold after the great ticket fiasco)
    2003 CBR954 (wadded into a little ball)
    1989 FJ1200 (sold)
    1993 VFR750 (fighter conversion - now sold)
    1979 Yamaha RD400 Daytona Special cafe racer
    Honda! Where's my 7th Gen VFR????
    Gave up waiting (for now) and bought an FZR1000.
    Jun 2006
    New England
    99 VFR 73 H1 TRIPLE
    281
    Later models pick up the speedometer reading off of the countershaft sprocket, so gearing changes will decalibrate your speedo. Not sure if a '91 still used the front wheel for speedometer...
    Mar 2007
    177
    Quote Originally Posted by flameface View Post
    3G's (mine is a 93) run the speedo drive off of the countershaft sprocket as opposed to the front wheel on a CBR (up to F2 IIRC) which has a speedo drive on the front axle. I just replaced it (initially) with a $10 bicycle speedo and pickup which I later replaced with a decidedly unsatisfactory Trail Tech computer (tach is a POS). The cable and drive was just too bulky without a fairing.....
    You could always add a magnetic bicycle pickup and speedo(mine's a Filzer DB4LW from MEC) for reference, at $10 it's a lot cheaper than a speedohealer or anything like that.
    Steve
    Delta, BC
    1989 FJ1200 (sold)
  1. Question about gear
    By NWA_VFR700F in forum Gear & Accessories
    Last Post: 10-23-2009, 11:46 AM
  2. Gear Question
    By jdubb in forum Gear & Accessories
    Last Post: 09-25-2009, 02:09 PM
  3. Question on rear shock swap...
    By brutus in forum 5th Generation 1998-2001
    Last Post: 05-12-2008, 09:56 AM
  4. Front Fork Swap Question
    By Bubba Zanetti in forum Mechanics Garage
    Last Post: 01-14-2008, 09:48 AM
  5. Windscreen Swap Question
    By mankaw in forum 6th Generation 2002-2009
    Last Post: 10-20-2003, 11:20 AM
