Results 1 to 5 of 5
Thread: 2002 VFR800 filter wrench
    Hi,
    I have a 2002 VFR800 Intercepter. Does anyone know of an oil filter wrench that works without having to remove the exhaust? And if so where I can purchase one? Thanks!!
    Re: 2002 VFR800 filter wrench
    I'd take the new filter (you bought?) to meijers (or the like). I found one that pretty much fit and had a square hole sized correctly to allow a wrench (with extension) to be put on it.
    After the first change, tightening by hand seems to allow you to get it off a bit easier.
    Jan 2003
    32
    Yes, go into your clothes closet, and find on old leather belt with a smallish loop buckle that looks ratty, and that you know you should have already thrown out.
    Take it to the garage, loop the tail end through the buckle, and wrap it around the filter. Pull.
    There you go! ::)
    Jan 2003
    36
    I got a regular filter wrench from my Honda dealer. It is a black cap shaped cup with squared sides to match the filter. You put it on the filter and attach a 3/8" (I think ) drive and ratchet. You have to pull the cooler hose down out of the way, but it is very easy. Don't force the cap on the filter. Put a thin film of oil on the cap and gently press it on the filter enough to get a decent bite. Your manual gives the torque, about 7 pounds. Hand tight is o.k., but firm! good luck
    Thanks guys!
  1. K&N air filter for 06 Vfr800?
    By MirrorBuster in forum 6th Generation 2002-2009
    Last Post: 12-25-2008, 04:19 PM
  2. Oil filter wrench - Where?
    By VFR02rider in forum Mechanics Garage
    Last Post: 04-24-2008, 05:03 PM
  3. New 2003 VFR oil filter requires an new oil filter wrench!
    By adhenri in forum Mechanics Garage
    Last Post: 08-31-2007, 11:07 PM
  4. 98 VFR800 Air Filter
    By Trekman in forum Mechanics Garage
    Last Post: 01-18-2004, 04:50 AM
