Old 06-22-2008, 10:04 AM   #1 (permalink)
motocrossscott62's Avatar
Last Online: 08-09-2008 10:23 PM
My Ride: 2007 YZ 250 2006 YZF 450 1993 VFR750F
1993 VFR 750 week on power
I still have not figured out why mr 93 vfr 750 is'nt running up to snuff. I put this imacculate bike back together after a friend of mine took it apart over 10 years ago to powder coat the frame etc. but never got around to it. I ride it to work every day ,it runs smooth with no skips ect. But it does'nt pull nearly as strong as it should.Did I miss something when I eliminated the pollution crap A.K.A air injection system, I made plates to go over were the chrome lines bolted up.My bike also has a full Two Bros. exhaust and a dyno jet kit, whick I've played with the needle valve clip slots to no avail.The bike run smooth but has the power of a 250 Ninja. Can any of you guys stear me in the right direction?? Also does anyone know of a good V-4 mechanic in the Jax. Fl. area?? THANKS for any help !!!!! Scott McCabe
motocrossscott62 is offline   Reply With Quote
Old 06-22-2008, 05:49 PM   #2 (permalink)
Moderator
WhiteKnight's Avatar
Last Online: 12-02-2008 07:38 AM
I don't know of any mech's in your area, but you might want to check the valve timing as well as make sure all vacuum leaks are plugged. Make sure the air filter is clean as well.
http://www.nrwhiteknight.net
Old 06-22-2008, 07:19 PM   #3 (permalink)
v4pwr's Avatar
Last Online: 11-12-2008 09:21 PM
My Ride: 1997 vfr750f
maybe the jet kit is the problem. i have heard these engines do not really take well to jetkits. i think it makes it run pretty rich but not for sure. i am still at stock carbs setup
v4pwr is offline   Reply With Quote
Old 06-22-2008, 08:54 PM   #4 (permalink)
Moderator
that could be. I thought about suggesting going back to the stock carb set-up, but thought that it mught be something else. If it is easy to go back the stock carb set-up, I'd do that first. I put a D&D on my 93 and never had to re-jet at all.
Old 06-23-2008, 03:03 PM   #5 (permalink)
Thanks guys for your repsonses, what do you think a good start on carb setup would be @ 11 ' above S.L. and the full Two Bros complete exhaust with a K&N filter?? The vacuum lines you mentioned....are they small lines under the carbs?? I noticed that the Carb Vacuum pistons do not open all the way when I run it with the air box open?? Thanks again!!
Old 06-23-2008, 07:53 PM   #6 (permalink)
Last Online: 07-07-2008 06:07 PM
I Have Seen Wrong Order For Spark Plugs Do This, I Would Check It With The Clymer Manuel, I Purchased A Bike That Was Doing This , Firing Order Was Wrong Corrected It And The Bike Was Fixed Instantly
razortongue1 is offline   Reply With Quote
mirrors bikerdadny VF/VFR Mailing List 4 06-20-2008 11:08 AM
Blackbird to a VFR – a daily, performance riding and touring perspective two4one General VFR Discussions 23 05-17-2008 04:10 PM
1993 VFR 750 running weak motocrossscott62 Third & Fourth Generation 1990-1997 9 02-06-2008 02:05 PM
Re: vfr Digest, Vol 38, Issue 48 zilvar VF/VFR Mailing List 1 05-28-2007 07:56 AM
Fwd: How many links in a 1993 VFR chain? Rajah VF/VFR Mailing List 1 05-23-2007 02:33 PM
