Hi everyone. Great website, lotta good info.
Just bought a pristine 94 vfr750 with 30,000 miles. All I've read about this bike is true. Glad I bought one.
One small problem. The bike keeps blowing the 10 amp horn/directional/brake light fuse. I'll put a new one in and it will work fine for a few miles then blow.
Any suggestions would be greatly appreciated.
Thanks, Andae
This fuse continually blowing is usually due to the earth wire on the rear light assembly being corroded
Thanks. I'll check it out and keep ya posted.
Found the culprit!
The right rear directional wire was grounding out on the sub-frame.
Thanks for the help.
