Old 08-11-2008, 07:54 PM   #1 (permalink)
tumminello123's Avatar
Last Online: 10-07-2008 04:36 AM
My Ride: 1986 VF1000R
Send a message via MSN to tumminello123 Send a message via Yahoo to tumminello123
Anyone know the steps for clutch lever replacement?
Well, because everyone made fun of the carbon "look" levers, I opted for the regular levers.
Bike: 1986 VF1000R
So, what I need to know now are the steps to replace the lever. I have a manual, but it talks about replacing the fluid and not removing the lever. I just need to make sure I don't screw it up since right now it works. Anyone know what the steps for removal and re-installation?
tumminello123 is offline   Reply With Quote
Old 08-11-2008, 09:22 PM   #2 (permalink)
SLOVFR's Avatar
Last Online: Yesterday 07:24 PM
My Ride: 97 vfr 750
Keep the Carbon levers...I like em. Otherwise remove nut from screw on bottom of pivot, remove pivot screw and replace levers...
SLOVFR is offline   Reply With Quote
Old 08-12-2008, 06:49 PM   #3 (permalink)
JamieDaugherty's Avatar
Last Online: 12-02-2008 04:01 AM
Here you go:
1) Take the old one off
2) Put the new one on
All kidding aside, it's really very simple and straightforward. As mentioned, it's just one bolt and nut.
Old 08-12-2008, 07:31 PM   #4 (permalink)
SLOVFR's Avatar
My Ride: 97 vfr 750
^ That seems like alot...anyone got any short cuts??
Old 08-12-2008, 08:14 PM   #5 (permalink)
jeff8478's Avatar
Last Online: 12-01-2008 05:11 PM
My Ride: 2006 Interceptor ABS
Shortcut:
Quickly replace old with new.
Hey you, yes you, pay attention!
jeff8478 is offline   Reply With Quote
Old 08-13-2008, 09:31 AM   #6 (permalink)
Longerfellow's Avatar
Last Online: Yesterday 04:33 PM
My Ride: 1997 Honda VFR750F 1996 Honda XR600R Baja
Shorter still:
R & R clutch lever.
Longerfellow is offline   Reply With Quote
Old 08-18-2008, 10:27 PM   #7 (permalink)
crustyrider's Avatar
My Ride: 1986 honda Interceptor 700 1985 Suzuki GS700E
even shorter: R&R C/L
crustyrider is offline   Reply With Quote
Old 08-18-2008, 10:39 PM   #8 (permalink)
SLOVFR's Avatar
My Ride: 97 vfr 750
rrcl ..
Old 08-19-2008, 07:18 PM   #9 (permalink)
bbwong's Avatar
Last Online: Today 05:50 AM
My Ride: '95 VFR
There is also a push rod that the lever pushes into the clutch master cylinder - just make sure it either stays in place during removal of lever or the push rod slots back into the master cylinder. Otherwise, it is as easy as previously posted. If you search the garage/maintenance section (i forget exactly where) a forum member did post step by step photo instructions.
bbwong is offline   Reply With Quote
Old 08-19-2008, 08:35 PM   #10 (permalink)
chris2711's Avatar
Last Online: 12-02-2008 07:21 PM
My Ride: 2006 Honda VFR
Just make sure all those little springs don't go flying everywhere.
Just kidding!
chris2711 is offline   Reply With Quote
Old 08-19-2008, 08:37 PM   #11 (permalink)
chris2711's Avatar
Unless you purchase used ones, the new set should come with instructions.
At least my Pazzo's did.
Pazzo Lever Installation WhiteKnight Body Modifications 26 11-18-2008 06:58 PM
What are the steps for clutch lever replacement? tumminello123 First & Second Generation 1983-1989 1 08-12-2008 01:45 AM
OEM replacement brake lever? (noob needs help) way2faded First & Second Generation 1983-1989 4 06-21-2008 10:44 AM
clutch lever replacement 02vfr800 Mechanics Garage 2 02-27-2007 09:27 AM
2000 VFR Clutch replacement stephanon2whls Fifth Generation 1998-2001 3 07-03-2005 06:36 AM
