Last Online: Today 07:47 AM
Very easy to do (should be the same as 4th-6th gens still I am assuming).....loosen the axle bolt, and then use the spanner tool to rotate the eccentric hub, retighten the axle bolt, and you are good to go.
Download the manual here if you are unsure. Downloadable Parts Catalogs and Service Manuals
| The Following User Says Thank You to derstuka For This Useful Post: | 93whitevfr (08-13-2008) |
Last Online: Today 10:09 AM
My Ride: 2000 VFR 800 fi
The bolt you loosen first is located at the very rear of the swing arm. The eccentric hub he is referring to is the gear looking thing on the right side of the swing arm.
Shop Steward:Chat Hooers Union, Local 151 |
| The Following User Says Thank You to drewl For This Useful Post: | 93whitevfr (08-13-2008) |
Last Online: 11-06-2008 02:25 PM
My Ride: 2004 VFR ABS Asphalt Black
Guys,
If this will help anybody, it is possible to adjust the chain without the tool kit. I didn't get one with my bike, and I haven't bought one yet, but I probably will. I'm not necessarily recommending it, but here's what I did: I had studied the shop manual, to understand how the eccentric hub adjustment worked. With the bike on the centerstand, I loosened the pinch bolt, and put pentrating oil around the adjuster ring. (not sure it needed it, but just wanted to make it easy). I took an allen/hex head wrench and put the end against against one of the teeth of the adjuster ring, and gently tapped on the "L" end. A punch with a flat end would work, too. Slighly firm taps, but gentle. It moved the adjuster ring, and the chain gradually tightened. Didn't mar or dent the ring at all. I re-tightened the pinch bolt, cleaned and lubed the chain, and all is well. Like I said, I'm not recommending it, but if you don't have the spanner wrench, all is not lost. The key is to be gentle and not bang up the adjustment ring.
ride safely-don't get hurt
| The Following User Says Thank You to geronpg For This Useful Post: | 93whitevfr (08-22-2008) |
Last Online: Today 03:06 AM
My Ride: '06 Interceptor
You can turn the clinch nut, it will also turn the eccentric hub. Retighten axle nut, all good!
Do like Derstuka said, down load. Mac |
| chain/ sprkt repl. w/pics | v4pwr | Maintenance | 4 | 04-05-2008 07:11 AM |
| Master Link Chain Replacement | Don Swanner | VF/VFR Mailing List | 0 | 10-12-2007 02:06 PM |
| Chain Problems, but possibly more | cailt | VF/VFR Mailing List | 13 | 06-02-2006 11:33 AM |
| Subject: Re: chain slack adjustment | Joe Speed | VF/VFR Mailing List | 1 | 06-01-2006 11:25 AM |
| RE: chain slack adjustment | Sullivan, John | VF/VFR Mailing List | 0 | 06-01-2006 06:35 AM |
