Old 08-16-2008, 06:06 PM   #1 (permalink)
Last Online: 11-09-2008 09:45 PM
6th. gen stalling when clutch is engaged
I have a 2005 VFR 800. The wiring recall was done last Oct. Lately while I am riding the bike, it stalls. It only happens when I engage the clutch to change gears as the bike is coming down off it's rpm's it just stalls. Sometimes when the bike is idling, if I rev it up, then take my hand off the throttle it will stall. Any sugesstions? I have checked it for codes and found only one which states the computer is not getting a proper signal from the pulse generator. It bike always starts the first time when cold however, sometimes after itstalls, it will not restart. You have to restart it 4-5 times. It will just start and then stall again.
Also, the bike will run warn, around 200F. Are their any after market thermostats that will open at a lower temp so the bike will run cooler?
dravera72 is offline   Reply With Quote
Old 08-17-2008, 07:16 AM   #2 (permalink)
bladrnr's Avatar
Last Online: 12-01-2008 04:08 PM
My Ride: 2000 VFR800FI
I'm not a mechanic but it sounds like what use to happen to carbuerated bikes when the valves are closing early. It happens when the you need a valve adjust. Usually it takes a lot to get FI bike to do this. This is just a guess though.
VFR's run hot in hot weather,especially in town. Is it hot where you live?
bladrnr is offline   Reply With Quote
Old 08-21-2008, 07:07 PM   #3 (permalink)
Well, riding the bike last weekend I was on the hiway when the outside temp was around 95F but if I let the bike idle long enough, the temp will go up to 220F+ Is this normal?
Old 08-21-2008, 08:14 PM   #4 (permalink)
eddievalleytrailer's Avatar
Last Online: 11-23-2008 08:27 AM
Your temp is normal. Maybe your computer isn't getting the correct signal from the pulse generator. That would cause it to stall, for sure.
Proud Member Sixth Gen Militia-1st VTEC Battalion
Old 08-21-2008, 10:35 PM   #5 (permalink)
Thanks for the reply. Could it be the pulse generator?
Old 08-22-2008, 08:45 AM   #6 (permalink)
Yeah. The pulse generator tells the ignition when to fire. A bad one or bad connection can shut her right down.
Old 08-23-2008, 03:49 PM   #7 (permalink)
marc28ni's Avatar
Last Online: 09-23-2008 03:04 PM
My Ride: 2002 Honda VT125 Shaddow, 2006 Honda XL125V Varadero, 2007 Honda CBF 600N and 2008 VFR 800ABS
Send a message via MSN to marc28ni
Good call, Hears one for you, I had a bad fill of petrol for a wee station down my road and my bike did the same thing. Just another thing to think about......
Life is like li#king out your girlfriend/wife, One slip of the toung and your in the sh#t
marc28ni is offline   Reply With Quote
Old 08-23-2008, 07:07 PM   #8 (permalink)
Banned
Last Online: 10-27-2008 09:50 AM
My Ride: 2007 rwb leo vince slips kn filter only mods
try turning your idle screw a few turns may help
elf800 is offline   Reply With Quote
Old 09-01-2008, 08:34 AM   #9 (permalink)
Adjusted idle to 1300rpm's. It seemed to help. I've ridden the bike about 30 miles and it has not stalled yet. Thanks for your help. One more question, would it be worthwhile to sync the throttle bodies? The bike does not seem to have the power it used to.
Old 09-01-2008, 08:44 AM   #10 (permalink)
Scubalong's Avatar
Last Online: Today 07:50 AM
My Ride: 2005 VFR800 (Death) 2006/09 Black (Japmaican) girl
Well known issue
Check the R/R this is common on the 5th and 6th Gen. A lot of riders replace with the heavy duty one and the problem go away. My have the same problem. I am waitting to see if the warraty cover my.
Scubalong is offline   Reply With Quote
Old 09-01-2008, 09:02 AM   #11 (permalink)
El Conquistador
ExciteBike's Avatar
Last Online: Yesterday 08:05 PM
My Ride: 2004 Honda VFR 800 Intercepter
Second that turning up the idle. I had my bike idling on the low side 1100rpms and then the weather hit a mild spell (low 80's instead of high 90's) my 04 was doing the same thing. Pull in the clutch to shift and it would die. I cranked the idle up to 1300rpms hasn't done it since. that was about 800 miles ago.
As far as the temp that's a completely normal temp range for the bike.
-There's a problem in the cockpit.
--The cockpit, what is it?
-It's the little room in the front of the plane where the pilots sit, but that's not important right now.
ExciteBike is offline   Reply With Quote
Old 09-03-2008, 10:18 AM   #12 (permalink)
Thanks again for your reply. One more question, what's the R/R?
Rebuilding Slave Cylinder Fixed My Clutch rjhartmann Mechanics Garage 1 04-07-2008 06:08 AM
clunking noise when clutch half-way engaged suprajake Mechanics Garage 2 01-25-2007 08:58 PM
Clutch wear; Sad but true. Jeremy Boron VF/VFR Mailing List 6 06-02-2006 07:19 AM
RE: Need some clutch help 95 VFR Darrin Blackman VF/VFR Mailing List 14 03-01-2006 02:13 PM
RE: Vfr Digest, Vol 23, Issue 24 Jeremy Boron VF/VFR Mailing List 3 02-27-2006 08:38 AM
