Old 10-03-2008, 04:10 PM   #1 (permalink)
Last Online: 11-04-2008 04:39 PM
My Ride: 1984 Honda VF500F Interceptor
1984 VF500F Valve Adjustment/ Dyno Jet Kit
Well I got a few more items I would like to do to my 1984 Honda VF500F, for these I thought some input would be nice.
1) Valve adjustment.. Should I take it into the shop and pay $150.00 or should I do it myself?? I've never done a valve adjustment but with the manual I feel I can do it, Just how well will the turn out be? I work at a repair station for aviation so the use of tools should not be a problem. How hard is it?
2) Installing a K&N Dyno Jet Kit.. I bought this NOS off ebay for a few bucks. I'm running a K&N air filter, aftermarket headers, and Supertrapp pipes will the jet kit be beneficial? How hard will it be to install, I cleaned the carb by myself when I bought the bike. The instuction says there is drilling involed, scary!
3) With that Jet Kit also came Spilt Fire Spark Plugs.. Now i've heard good and bad things about these. What's your insight?
Thanks for any of your thoughts,
Crazyridin'
Crazyridin' is offline   Reply With Quote
Old 10-06-2008, 12:16 PM   #2 (permalink)
masonv45's Avatar
Last Online: 11-13-2008 02:00 PM
1. Do it yourself. ValveTrain/ValveClearanceAdjustment - SabMagFAQ
2. Does the Supertrapp replace the entire exhaust system. If not, you more than likely don't need to rejet. Even if you do need to rejet, I'd up the slows and mains one step and send the Dyno Jet kit back. Everyone I've talked to says it's not worth it.
2a. The drilling is drilling a hole in the sides of the the vacuum slides for faster throttle response. But faster throttle response is not needed.
3. Use the recommended NGK plugs...unless you feel that lightening your wallet will make the bike go faster.
1985 VF700F
Memphis, TN
The Following User Says Thank You to masonv45 For This Useful Post:
Crazyridin' (10-06-2008)
Old 10-06-2008, 01:34 PM   #3 (permalink)
pjvtec's Avatar
Last Online: 10-28-2008 04:19 PM
My Ride: '04 VFR800,'06 CHF 50,'82 CM250C
Answers to 1. and 2. Fear not if you work on planes. 3. No F - ing way!!! NGK all the way.
Thank You For The Dream Mr. Honda
Honda, Performance First
pjvtec is offline   Reply With Quote
The Following User Says Thank You to pjvtec For This Useful Post:
Old 10-08-2008, 02:52 PM   #4 (permalink)
JamieDaugherty's Avatar
Last Online: 11-17-2008 06:30 PM
DO NOT install the Dynojet kit, they are simply awful. The drilling of the very expensive slides would be huge mistake. Opt for a Factory Pro kit instead, they are the only kits that I've found that actually dial-in right.
The Following User Says Thank You to JamieDaugherty For This Useful Post:
Crazyridin' (10-08-2008)
Tags
valve jet kit vf500f
83 VF750F valve adjustment question my83 Introductions 4 09-09-2008 12:59 PM
Valve Adjustment - Chicago Area daeven VF/VFR Mailing List 1 12-31-2007 10:57 PM
parts for a valve adjustment digger First & Second Generation 1983-1989 3 06-05-2007 07:34 PM
valve adjustment parts digger VF/VFR Mailing List 2 03-26-2007 08:58 AM
Valve adjustment on a'93 VFR750 Olivier VF/VFR Mailing List 1 04-03-2006 04:19 PM
