I have a 2001 Honda VFR800. It has 14000 miles on it.
How do I change my coolant? I was going to just unscrew the hose from the underside of the radiator, but I would imagine that wouldn't get all the coolant. Plus that would cause air bubble problems.
Anyone got a write-up? I don't have an owners manual, or I would have looked.
2000 Honda Interceptor
Micron exhaust - heated grips - Black Windscreen - Solo Seat Cowl
Merlin 2000 Security System - Real Carbon Fiber Tank Protector
55w Piaa Ion Crystal H4's - white led boogey lights
Download the service manual from here. There is a drain plug on the water pump and on one cylinder head. There are pics in the manual of plug locations.
'00 Interceptor
Sargent seat - HeliBars - Yoshi pipe - ZG ST - K&N
thanks a bunch
Warning: When you first remove the drain plug from the water pump housing, the coolant will shoot a 2 foot long stream straight out of the hole.....don't get taken by surprise!
The replacement sealing washers for the drain bolts are part number 90463-ML7-000.
It is fairly simple. Just remember to check the level once or twice after refilling.
Also, air like to get stuck at the fan switch located at the top left radiator corner.
It will cause the fan not to come on. A quick turn or 2 will allow the air to escape.
Just changed mine yesterday (1998 model). The drain plug on the engine block is hardly worth bothering with. About one ounce of coolant came out when I removed it.
