Results 1 to 30 of 30
Thread: Who manufacturers the oil filter for Honda???
    Jul 2007
    Camarillo, Ca
    2006 H-D Softtail Springer Classic 2007 Honda VFR Interceptor
    46
    After spending $14+ at the stealership last weak for my oil filter, I began to wonder..... Who does Honda farm out to manufacturer its oil filters? I know that we could argue at great length about quality, but what is comparable to the Honda filter at a reasonable price? My god, the filter for my Harley at the stealership is only $8.95!!!!
    Carl
    Member ralph66's Avatar
    Sep 2008
    Oroville, CA.
    07 VFR 07 H-D STREET BOB
    74
    go with K&N about the same price and better filter also easer to get off during the next oil change.
    Senior Member Action's Avatar
    Aug 2006
    Albuquerque
    2004 VFR
    787
    These will all fit. I like the PL14610
    About 2.5 inches long.
    Purolator Pure One PL14612, about $6.
    Mobil M1-108, about $12. Made by Champion.
    Bosch 3300, about $6. Made by Champion.
    About 3.25 inches long.
    Purolator Pure One PL14610, about $6.
    Mobil 1 M1-110, about $10. Made by Champion.
    Bosch 3323, about $6. Made By Champion.
    WalMart SuperTech ST7317, about $2. Made by Champion
    Action
    2004 VFR: Heil Bars, BMC, 2 Bros, Fender Elim, Heated Grips, +2 rear sprocket, DID gold chain, PCIII, Delkevic Headers. Tires- Pilot Road 2CT's
    The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts. - Bertrand Russell
    "Sorry Baby, I had to crash that Honda" - Pulp Fiction
    Jul 2007
    Camarillo, Ca
    46
    Are the filters made by Champion all identical with only the packaging/labels changed? And are there any differences in construction/filter elements/micron ratings of the filters, or all they all constructed to the same standards?
    Aug 2006
    Albuquerque
    2004 VFR
    787
    Senior Member Rev's Avatar
    Oct 2006
    Olympia,WA
    1994 VFR
    644
    The WalMart brand is the way to go (unless you don't shop there). Slightly longer filter means more filtration, and you can get your synthetic oil there too.
    Capo - 4G Mafia
    1994 VFR - H4 Silverstars, 2 Bros. SS/CF exhaust, re-snorkled, chopped rear fender, amber rear running lights, Metzeler SporTec M1s, forks raised 10mm, 929 shock mod, Zero G Double Bubble.
    The Dude
    reg71's Avatar
    Feb 2006
    Central Coast, CA
    1998 VFR 800, 2001 GSXR 750 (track bike) 2003 YZ 450 F, 1990 Suzuki DR 100 (step son's) 1998 Honda CR 80 (step son's)
    5,811
    Blog Entries
    40
    if i ever find a good source for the puralator i intend to buy it. anyone have a link to a discount online price so it makes up for paying shipping?
    Reg71 - Central Coast, CA
    98 VFR 800 - 5G Brotherhood
    Senior Member bluespecv03's Avatar
    Oct 2008
    Daytona Beach, FL
    2005 Honda Interceptor VFR800
    127
    Purolator PL14610 and Shell Rotella T!
    Chris Jones
  9. #9
    Senior Member bitterpil's Avatar
    Mar 2008
    Northern Virginia
    2006 Honda VFR
    582
    Answer to your question
    OIL FILTERS EXPOSED! - Honda OEM <<<------Link
    All oil filters are not created equal. Some filters have so much filter media that it inhibits the flow of oil when cold which requires the activation of the bypass valve to allow oil through to lube the engine on cold starts. Only issue with this is that some filtes require a higher PSI to open the valve than the OEM filter from Honda. While the higher PSI will be reached and oil will flow, the OEM filter's valve will open quicker to let oil flow during the start. This is not to say there aren't other quality filters on the market, there are. I am just saying do your research before you switch off of the OEM.
  10. #10
    Senior Member VIFFER RIDER's Avatar
    Jul 2009
    Socal
    2002 Honda VFR800 2008 Suzuki GSX-R750
    246
    Quote Originally Posted by ckamin View Post
    Carl
    Its made by Filtech, they are the same as the ones you can find at the Triumph dealers as well for the Daytona 675. If you want to buy aftermarket you can run a Nissan oil filter pn# 15208-65F0C for $5-6 or any equal sized filter with thread M20 x 1.5mm which is pretty standard for many Nissan cars. Look around for oil filters that fit the Nissan 350Z, they are the same size, design, and thread specs. Sorry for the old thread bump but i figured i'd to add this this thread.
    2002 Honda VFR800 Interceptor
  11. #11
    Junior Member AskMeLater's Avatar
    Mar 2009
    Amarillo, Texas
    2007 Interceptor Red/White/Blue
    No apologies necessary, VR. Knowledge is power. I just paid $13.00 today at the dealership for an oil filter (ok, ok, it was only $12.98, but what's 2 cents amongst friends? ;) ) and I about had an attack. It's outrageous, in my opinion, to reward your loyal customers by charging them exorbitant prices for such common items. I will definitely look elsewhere next time.
    Quote Originally Posted by VIFFER RIDER View Post
  12. #12
    Senior Member midias's Avatar
    Jun 2007
    Rochester NY
    1986 VFR750F and 1982 V45 Magna
    450
    I know for a while fram was making honda car oil filters.
  13. #13
    Jul 2009
    Socal
    246
    Quote Originally Posted by midias View Post
    You are correct, Fram (Allied Signal) is still making oil filter for Honda's automotive side, but their motorcycle side is Filtech.
  14. #14
    Banned
    Jan 2009
    purgatory...........................................................................................
    6th gen blues white red black yellow silver
    1,039
    an oil filter is just as important then what type of oil you use. as metioned earlier some do not filter out as much and the valve doesn't open as soon or as often.. I read an oil filter comparision (google it)for cars and found out the mobil one filter is a better way to go; fram are junk use plastic parts I would not put a car filter on a motorcycle thread size may be the same but the pressure is different..royal purple is an awesome filter as well 15 dollars, mobil1 13dollars, you really think a 4.95 fram is as good?? next time you are bored look at them in auto parts store and compare the mobil one is all steel better valve and rubber seal is heavier.. just better from my reasearch and from comparing them on different cars..hope this helped but people spend up to 12 a quart on oil then use a cheap filter
  15. #15
    Jul 2009
    Socal
    246
    Quote Originally Posted by deepdish View Post
    I bought 1 OEM Honda filter for the first oil change, probably never again. $14 for a oil filter is a rip off. Next time im running some Nissan oil filters for $5 they have then in short and long versions. On a side note, i wonder why VFR's didnt come with OEM magnetic drain plugs? My Suzuki comes with it.... I guess time to buy one of those too.
  16. #16
    Uber Guru mello dude's Avatar
    Jan 2006
    '98VFR800 and '99 Valkyrie - one to go fast, one to go slow, not necessarily in that order.
    2,367
    Lately I'm running the Bosch 3300 - $4.99 at AutoZone - seems to be fine.
    MD
  17. #17
    Jul 2009
    Socal
    246
    On a side note, i have been hearing very good review's about Honda of Japan oil filters called HAMP filters. I might give these a try since they are really cheap $8~ Japanese oil filters with good filtering, lots of pleats and made to work specifically with VTEC engines. I ordered some today, ill let you guys know how they turn out when i get them in tomorrow..
  18. #18
    Uber Guru RVFR's Avatar
    Jan 2006
    97 VFR750
    4,175
    Blog Entries
    Oh man what a topic, I too thought the OEM price is a bit out of line, so I started doing some research and came up with a WIX filters being about as good as you can get, especially for the money, this one was $7.99 Being WIX also got their start making Hydraulic filters for a many important machines, made sense they knew a thing or two. Just so happened I tripped over these via getting my Amsoil at all places LOL at a rental equipment establishment. Since they go through a lot of oil and filters, it made sense to get their feelings on the subject. and wouldn't you know, Wix #51358 is just the ticket. Funny on the box it has a label saying #1 filter for Nascar.. Oh brother, now there's a reason to buy it huh? NOT!!!
    Awe. the best way to get around.
    www.whirl.me
    www.gowhirl.com
  19. #19
    Aug 2006
    Albuquerque
    2004 VFR
    787
    Quote Originally Posted by mello dude View Post
    MD
    Agree! They also had Rotella Synth for the same price as Wal Mart.
    Action
  20. #20
    Jul 2009
    Socal
    246
    When i changed my oil a couple of weeks ago, there was alot of sediment on the bottom of the drain pan, it looked like black sand or dust. Is this the clutch material? If so, why is there soo much of it??? Ive had small amount of it come out of my 750 before but it was like really little, on the VFR it looks like the whole bottom of the drain pan was covered in it.
  21. #21
    Jul 2009
    Socal
    246
    Ok i got in the HAMP filters today, they are EXACTLY like the factory Honda Motorcycle filter with the exception of its height and obvious color (its a larger version of the OEM Honda filter) the material color and texture looks to be the same, as well as the support screen.
  22. #22
    Sep 2009
    Bham, AL
    07 RWB
    Viffer,
    Where did you get those Hamp filters from??
  23. #23
    Jul 2009
    Socal
    246
    Quote Originally Posted by leadfootedfool View Post
    Viffer,
    We sell them at work, if you want to buy some PM me and let me know how many you want and i can round them up for you.
  24. #24
    Senior Member e cabrera's Avatar
    Apr 2009
    San Luis Potosi, MEXICO
    VFR 800 Interceptor 2000 and CBR 600 RR 2007.
    155
    hello¡
    does anybody know something about FRAM oil filter PH6607 ????????(extra guard)
    I bought 3 for my VFR and CBR600RR, I've read bad references about FRAm filters,
    In my Honda dealer offered me an oil filter for the Honda Civic and told me that it's the same for the VFR¡¡¡¡¡¡¡¡¡¡
    Is there any difference between cars or motorcycle oil filters??
  25. #25
    Senior Member MiddleAgeCrazy's Avatar
    Jan 2009
    Kentucky
    1971 Yamaha Mini Enduro-87 VFR F2H-08 VFR 800
    122
    I need to do oil soon and this is a great topic. I think the price is highway robbery for a filter. I may be married to the Honda filters for awhile. A little intimidated by the fuel injection system I bought into the six year warranty... .
    Major - Sixth Gen Militia (Reserve Unit) - 1st VTEC Battalion
    You Meet The Nicest People On A Honda
  26. #26
    Jul 2009
    Socal
    246
    Quote Originally Posted by e cabrera View Post
    hello¡
    Fram is crap, a poorly constructed filter with no emphasis on quality. On a side note buying that Honda car dealer filter is no different but the cost, the Honda parts dist center switched the Filtech made ones for the shitty Fram ones, only difference is its painted blue. Do yourself a favor and buy something with some emphasis on quality. This is why the Hamp filters are famous around the Honda crowds because its a high quality filter thats far better then OEM (because its not Fram) and is built for good filtration. The HAMP filter is exactly the same as the Honda bike dealer ones (same maker) only difference is the price and its slightly longer (good thing more sq in surface area).
  27. The Following User Says Thank You to VIFFER RIDER For This Useful Post:
    e cabrera (09-18-2009)
  28. #27
    Jul 2009
    Socal
    246
    Take a look here to compare: Motorcycle Oil Filter Comparison
  29. #28
    Member revguy's Avatar
    Apr 2009
    North Bay Ontario
    1985 750 MaximX 2000 VFR
    I find that oil and oil filters are cheap compared to buying a new engine! I know that if I buy a honda oil filter and oil for my bike I wont have any problems .
    My ride gives me lots of pleasure and If I have to spend an extra $20.00 a season to buy genuine parts I am ok with that. If I ever bought a porsche I wouldent buy my oil and filter from walmart!!!
  30. #29
    Aug 2007
    2,160
    Blog Entries
    7
    I forgot, it already has snowed in some parts of the country this year.
  31. #30
    Apr 2009
    North Bay Ontario
    Arrrrg dont remind me ......... I may have been out on my last ride of the season and not even realized it .....
  1. New 2003 VFR oil filter requires an new oil filter wrench!
    By adhenri in forum Mechanics Garage
    Last Post: 08-31-2007, 11:07 PM
